I would only increase the fuse size by 5 amps if I could not find the right size.... If you have a direct short it will blow the fuse if it is a little over sized. If you use the range alot for a long period of time and if the wire size is matched real close to the fuse size then you could run the risk of getting the wire to hot and cause a fire hazard if you use a larger fuse then is needed..... Hope this helps.
