Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
Can't restart, can't connect
My disk is suddenly impossible to shut down, and I can't access it at all. Normally, pressing and holding the blue light button on the front for thutton three seconds shuts it down, but it won't work. I tried to disconnect the power cable, and then connect it again, to restart the disk. But when I reconnect the cable, the button goes blue (that is, I don't have to press it to turn it on). It's like it doesn't want to shut down at all.
Please, can anyone help me. I have got all the photos of my 2-year-old son on this disk, and I am DESPERATE!!!! PLEASE!!!
  • 6 more comments
  • Sarah 123 Aug 07, 2008
    I opened a support case with LaCie, and yesterday they sent me a new power adapter. This solved the problem completely, and my backup process has been running all night long. So, if someone has a similar problem, it might be a good idea doing this. I am so releived the photos and videos of my son are safe, and I will always make backups in the future... :-)
  • sergio_roma Sep 09, 2008
    I've a 1TB Ethernet Big disk with the same problem, I've opened a ticket at the LACIE support but after a quick answer where they suggested to find another AC Coverter (HOW=??) they disappeared!!! Ideas how to wake them up?
  • Anonymous Oct 14, 2008
    Disk will not power down. Blue light is constantly on. LaCie Ethernet Big Disk 1.5 TB
  • Anonymous Nov 05, 2008
    Same problem here.  After a quick power outage (a flash), the drive became inaccessible.  It won't power off when the button is pushed.  I guess I'll try to get a new power adapter.
  • fliptopbox Nov 28, 2008
    Yip me too. Exactly the same smptoms. Yesterday it was working perfectly, today I noticed it was not on the network, ping no response, and the blue light was flashing rapidly. So I pressed the button and it powered down. After it rebooted the light now stayes solid blue. Not network access, and no USB access. I hope it is just a controller failure, I have a lot to loose. Ironically this is my backup drive :( LACIE please respond!
  • Anonymous Dec 26, 2008
    I can kind of have the same problem and thanks to your 'ticket' here I know what to do.
    Thanks for the information.
  • siripo Dec 26, 2008
    I have the same symptoms, I just measured voltage output of th e power supply and everything seems to be ok.
    After opening the case I can hear a high pitch noise coming out of the controller board which I can't explain. The noise is still there even after unplugging the hard drive.
  • Anonymous Jan 08, 2009
    I had a LaCie Edmini who stopped working. I contacted a local data guru who picked out the hard drive and connected it to a Linus system and by the help of this rescued more than 8000 pictures for me!
I had exactly the same problem with two of these hard drive before. The first one was solved by using a new power cable. The second time, I assumed it was this, but it wasn't, and in desparation, I opened up the unit (warning, this voids the warranty!), and put the hard drive in another lacie enclosure, and the hard drive worked perfectly.
So don't worry - the hard drive is almost certainly safe. Either buy another unit, and try first the new power cable, and second, the new hard drive enclose. Or open up a support ticket with Lacie, and you may need to send it back to them. But insist that the hard drive still works, and that they replace the housing / psu, not just give you a new unit.
I hope this helps, I know just how frustrating this problem is. But your pics should be safe!
Posted on Aug 05, 2008
I had a similar issue w/lacie ethernet bigdisk 1TB. Couldn't access drive, found that it was making the clackety clack drive death sound and was hot to the touch. Powered down and tried to restart but no blue light, apparently dead. It always ran hot. Pulled drives and connected directly to computer w/sata connector, drives tested good. Put all back together but still didn't work. Put in freezer overnight, pulled out and hooked up - was able to get blue light to come on but nothing else, no ethernet lights. Strange, the blue light would come on when I plugged the unit in, I didn't have to press the button, nothing wrong inside of case, but unit not really functioning. Also, as you said, I could only turn the light off by unplugging. FIX: As a last resort, I pulled the circuit board, baked it in the oven at 360 degrees F for 15 minutes, preheat oven to 360, immediately took the board from the oven to the freezer for 15 minutes. Put back together and the dang thing works perfectly now. I soldered the fan to the internal 12v line so it runs continuously and now it runs very cool. My guess is that the controller had a cold solder joint somewhere. Hind sight says I should have returned it to Lacie for a new one, I think they would have worked with me even though I opened the case.
Posted on Jan 18, 2009
  • 101 Answers
Please check the smps this type of problams are coming whaen smps is not working corrctley than cheack with ram slots also please verfiy the whare the problam is check one be one
Posted on Jul 23, 2008
Won't power on
Hold the power button down for about ten seconds and it'll actually turn off. Press the power button and see if it restarts.
Nov 03, 2015 | Computers & Internet
Mb324ll/a white screen
1.Try a Safe Boot
Mac OS X 10.2 and later Safe Boot includes disk checking and repair. First start your Mac in Safe Mode. To do this, shut down your Mac. Now Turn on your computer by pressing the power key while holding down the Shift key. When you see the Apple logo, release the Shift key. After your Mac fully starts, restart your computer normally without holding any keys/buttons during startup. Note that Safe Boot is slower to boot.
2.Run Disk Utility
Turn your Mac off by holding down the power button for a few seconds. Turn on your Mac and hold down the Command and R keys until you see the Apple logo. Then you should see a "Mac OS X Utilities" window. Select Disk Utility, click your OS X hard drive and select verify/repair disk.
3.Reset PRAM
This may fix your boot failure. PRAM ("parameter random-access memory") stores some of your settings. You may reset PRAM. To do that, turn off your Mac. Now turn on your Mac. Then, immediately, hold down the Option-Command-P-R keys until your Mac restarts. When your Mac is starting up, release the keys.
4.Reinstall Mac OS X
If nothing above works, you may try this. Your Mac needs to be connected to the Internet. See number#2 above. Follow the same steps. Restart your Mac and hold down the Command key and the R key until the Apple icon appears; when you see the Mac OS X utilities window, select the Reinstall option.
Mar 13, 2014 | Apple iMac A1224 20" Core2Duo 2.66GHz 2GB...
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
Factory reset lenovo g580
Step 1:
There are a variety of reasons you may need to reboot a Lenovo laptop. These can include the installation of a new program, the dreaded blue screen of death or to free up memory that has been hijacked by a program that is now closed. There are three ways to reboot and all are simple to accomplish.
Click on your start menu button on your screen. Click on "Shut Down" or "Turn Off Computer." Click on the drop down box if you are running a version of Windows before XP (such as 2000 or 98). Select the "Restart" option and then click "OK." On XP or later versions, click on "Restart." The laptop will then reboot. Press and hold down the "Alt," "Ctrl" and "Shift" keys simultaneously. This will bring up the Task Manager. Pressing and holding the same keys again will force the computer to shut down. Press the power button to reboot the computer. This feature should be used when the mouse has stopped working and you cannot access the start button. Hold the power button in the "Off" position for approximately 5 seconds. This will force the machine to shut down. Press or slide the button again to reboot the laptop. Use this process when you get the "blue screen of death" or the computer is not responding to either the mouse or the keyboard.
Feb 22, 2013 | Lenovo Computers & Internet
When i start using my laptop , suddenly white screen and forcible shutdown,.
It sounds like it's overheating, make sure the airways are clear of dust and listen for the sound of the fan inside, this could have failed..
if the processor overheats it automatically cuts out and what you describe is exactly that..
good luck !
Mar 30, 2017 | Computers & Internet
My mcintosh screen become locked so I turned it off and waited about 1/2 hour before turning it back on. It took a long time before the screen turned blue and thats where it sits. Nothing else has pulled...
Try rebootint with your OSX disk in the dvd drive. then before you would hear the chime, press and hold the C key down on your keyboard. This will boot from the DVD and once it has finished loading (may take some time) will ask your to choose your language. After this go to utilities in the menu at the top and click on Disk Utility. When this opens, click on your hard drive on the left hand side (highighted in orange in picture), and then click repair disk and after that completes click repair permissions. (see picture)fairplay23.png After all of this shut down and restart your computer without the OSX dvd in the drive and it should boot normally.
Let me know if this works
Mar 10, 2011 | Apple iMac Desktop
How do I reboot vista laptop in order to remove radial point
a reboot is always a last resort!!! a better option to remove a program is to access control manager by pressing ctrl, atl, delete at the same time. when the prompt window is opened look through both processes and services tabs for anything related to the program hit stop process then just go to start>control panel>add/remove program. if that doesnt work restart your computer in safe-mode. if its a vista hit the power button let it rest for a sec then restart it. since the computer was improperly shut down it will ask if you want to start windows normally. don't instead choose start in safe-mode when it starts everything related to radial point will be shut down making it easy to remove the program through control panel. if you still whish to reboot shut down your computer by opening the start menu and in the lower right corner select restart. when the comp. restarts and the logo appears hit f8 quickly (you only have about 5 seconds before it restarts normally) choose boot with disk insert your start up disk and the computer will restart and all non-default programs will be lost. radial point will finally be defeated but at what cause? at what cause!!!??
Nov 14, 2009 | Microsoft Windows Vista Ultimate Edition
My dell gx-270 power keeps shutting down.
hmmm,
Dont worry just boot your computer using Bootable disk or windows installation disk, enter into Recovery console by pressing"R"
type the Administrator password if any or simply press "Enter".
At the command prompt type-"fixboot"
once done restart your computer normally.
Mar 25, 2009 | Dell OptiPlex GX270 PC Desktop
My XPS 1530 will not shutdown, it only restarts
Try running chkdsk /r and then restart the computer. to do that, click on START, RUN, in the open field, type 'cmd' and press <enter>. A dos window will open. At the blinking cursor, type 'chkdsk /r' and press <enter>. You will get a message that the drive can't be locked and do you want to run it the next time Windows starts. Type 'y' and press <enter>. Now shutdown the computerand restart it. Chkdsk will run and it may take some time. Depending on your installation, you will see a blue screen that will show the progress. Sometimes the screen will stay black and the hard drive light will flash. That's ok. Let it run until Windows loads. Wait until it is completely loaded and then try shutting it down normally.
Good luck and let me know how it works out.
Feb 07, 2009 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Open Questions:
See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
1,054 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
