Question about Kirby G6 Bagged Upright Vacuum
Kirby G6 attaching fluffer brush on shampooer
I can't seem to remember how to attach the fluffer brush on my shampooer and I was wondering if you could offer me any help.
    Problem Solver:
  • 7 Answers
Sure can,
You have two choices,
1.) To use your shampoo attachment, you'll need the fluffer shield, To set up the attachment seperate the tray assembly (the part that holds the roller brush) from the nozzle assembly (the part that attaches to the machine). Now seperate the roller brush from the tray (easiest way is to pull the belt). Insert the roller brush into the fluffer shield (it only goes one way). Insert the fluffer shield with the roller brush installed into the nozzle assembly the plastic shield will be faced towards the front of the machine. Turn belt lifter to where the red arrows match and attach to the front of the machine. Turn belt lifter to where the green arrows match and you should be in business.
2.) Your using the floor buffing attachment it the easiest method just put on like the floor nozzle (thing you vacuum with).
Posted on Aug 23, 2008
I cant remember how to change my kirby diamond edition from a vacuum to a shampooer
Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby Diamond Edition, Kirby Generation 3, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Instructional Video On How To Attach The Kirby Generation Series Carpet Shampoo Attachment:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this video was helpful to you. Please feel free to request a clarification if you have any further questions about the installation, I'm always more then happy to answer any question, seriously.
If you did find this video helpful, please kindly rate my soltuion as Helpful by clicking the Thumbs Up Icon at the the bottom right hand corner of this page.
Thanks for watching!
Chris
Mar 21, 2010 | Vacuums
How do i attach the shampooer to my g6 kirby
Greetings,
Here's an easy to understand and follow video review on how to attach the carpet shampooer to the Kirby Generation 6 (G6). The model that's being used in this video is a little newer model, the Sentria, but the procedure to attach the carpet cleaning attachment is the same exact repair on the Sentria as it is on your Kirby G6 vacuum.
I hope this helps!
If that helped, please be kind and rate the video as helpful by clicking on the Thumbs Up Icon below. If you have any questions about how to install it, please just request a repair clarification and I'll be more then happy to help you.
Chris J.
Jan 18, 2010 | Kirby G6 Bagged Upright Vacuum
I need to know how to attach the carpet fluffer to my kirby ultimate.the roller is to small for the head.am i missing a part.thanks judy
Most likely you are missing "Fluffer Sheald", which slides into shampooer head and then roller slides into it. You could try to get it at your local dealer. Other alternative to get "Floor Buffer", and use it for carpet fluffer:
http://www.goodvac.com/Kirby_floor_buffer_kit_p/k-acc-flrcr.htm
Good luck'
Rocky
Jan 02, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Where does the carpet fluffer to on the kirby shampooer
you remove the 'vacuum' head and use the same one as for the shampooer (on mine at least)
Apr 26, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
Apr 11, 2009 | Kirby G6 Bagged Upright Vacuum
Shampoo does not sud
The suds screen is not there or is somewhere in hose elbow. Click HERE and read the tip about installing the suds screen.
If you want to see where the screen is supposed to be installed - see out Kirby shampooer manual HERE.
Good Luck
Rocky
Apr 03, 2009 | Kirby G6 Bagged Upright Vacuum
Carpet fluffer
take the brush attachment off. The carpet fluffer will attach the same way as the brush attachment
Mar 01, 2009 | Kirby G4 Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Are there hand tools you can use with Kirby shampooer?
I love my Kirby and shampooer, but I am wondering if there are any ways to clean stains in small/tight spaces (in corners, between furniture, etc)... my old carpet shampooer had a "hand tool" attachment with spinning brushes, but I don't see anything similar for Kirby... I imagine I could put a tiny bit of solution down and use the zip brush, but I'm wondering if anyone has a better idea...?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe that Kirby does make a spinning brush and If I remember it is a round brush that spins and probably will not get into square corners – suggest using a scrub brush with the Kirby Shampoo for corners and steps for areas that you cannot get into – use an old spray bottle to wet down the area that you are cleaning and use the scrub brush and if you do find the Kirby spinning brush that will do the large areas. Feel free to contact the Kirby factory phone number and website listed below:
http://kirby.com Contact Us By Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
688 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
