Question about Hitachi Televison & Video
57uwx20b no picture and sound - Hitachi Televison & Video
We lost power today and our 2002 Hitachi 57uwx20b, has no picture or sound, yet the power light is on...any ideas. Thanks
Posted on Dec 09, 2010
Signal Problem
When the sound is working and the picture is not it indicates the main power supplies are working but the picture supply is not. The picture supply that powers the projection tubes is a high voltage generator and is very expensive to repair. Not even most tv techs now how to troubleshoot them. So, I cannot recommend you repair it yourself unless you are a trained high voltage tech.
The cost of repair - my wild guess - would be around $300. However, the real cost can only be determined by someone who can make an accurate diagnosis - which will require a hands-on approach the problem.
If you have any other problem please ask me..
Goodluck,
Please don't forget to rate me as fixya..
Feb 09, 2008 | Televison & Video
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
How do I set up an antenna for tv signal with my 57uwx20b? Do I need a special code to put into the converter box?
U planning to get free air tv?No need for a converter box,ur tv have digital tuner inside.Just plug in ur antena.Go to ur tv menu go to setup pick air scan all ur channels,well get all free air channels.
Feb 12, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a hitachi 57uwx20b that had distorted
If the problem "distorted picture" was red and blue lines everywhere you may have a shorted convergence IC and the set may be in shutdown; someone needs to determine by unsoldering the two convergence IC chips and then trying to turn the set on; if they are unsoldered and the set comes on---one of them is the trouble----also you can look around them at a number of small resistors to see if any are discolored or look burnt--If you need more direct assistance my email address is:
etower.766@netzero.net
The convergence ic chips are usually located on the right side of the set as you look at it from the back on a large finned piece of metal(it is a heat sink to keep them cool).
Aug 11, 2009 | Hitachi Televison & Video
Hitachi, model 57UWX20B ghosting?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 57UWX20B 57 in.
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 08, 2008 | Hitachi 57UWX20B 57" Rear Projection...
Hitachi 57uwx20b
First of all there is no light engine inside your set. Your model is CRT based. Can you better describe what you mean by the green only working occasionally? What exactly is the picture doing? Also, please confirm that your model is: 57UWX20B.
Thanks,
Dan
Sep 05, 2008 | Hitachi 57UWX20B 57" Rear Projection...
Magnavox model 6P5440
You can turn up the Screen controls in back of set. Look for the focus block that has 6 controls on it. 3 are for the screen and 3 for the focus, in each color Red, Blue, Green. need to turn evenly to keep color balanced. On set turn color all the way down and then get a good black and white picture.
Sep 14, 2007 | Hitachi 57UWX20B 57" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
