Question about Zebra Z4M Printer
Label Printing stuck in queues
I have 2 Zebra Z4M printers which are shared across the network. It prints labels in large amount. Often we get errors in the printer queues and it would stops printing after the first patient. After I turn off the printer and turn it back on, printing resumes. But then it would stop again and I have to repeat the process. I contacted Zebra corp and they said the Z4M have been discontinued and they do not support it anymore.
  • Thien_MJH Jul 29, 2008
    Seem like we have a lot of people with this issues and none of these so call "experts" know the answer.
    Scholar:
  • 185 Answers
Yes that is correct the Z4M is not supported any longer as they have reached End Of Life although parts are still available. The problem will be because the printer hasn't got enough memory, the Z4M uses flash RAM installed on the Main Logic Board. These might not be readilly available, another thing to use would be a Print Buffer. You should still be able to get them. The idea is to control the amount of data that is flowing to the printer, if the internal buffer fills up it will corrupt the data and a reboot is required.
Posted on Oct 29, 2009
    Champion:
  • 254 Answers
I think your problem comes from your spool server. Check if you can select not to reprint on errors. As far as the error issue is concerned, i need to konw the reason of the errors to help
Posted on Sep 03, 2009
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from...
if is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Nov 04, 2010 | Zebra Z4Mplus Label Printer
Delay in printing labels with Zebra Z4M
Set in the driver the size of the label and print mode to Tear off.
Roberto Martinez
Jul 22, 2009 | Zebra Z4M Printer
Printing half the vertical, no matter what size label in use.
Some drivers adjust the length of the print area, regardless of the length of the label. Do calibrate the label and also verifies that the margins are zero.
Roberto Martinez
Jul 21, 2009 | Zebra Z4M Printer
Zebra M4 is printing blank labels
Did you switch your ribbon as well?
Jul 06, 2009 | Zebra Z4M Printer
Zebra zm4 won't print labels all the way.
Please check your driver settings, you will probably find that you have the printer set to use the 2x2 labels instead of the 2x4
Jun 23, 2009 | Zebra Z4M Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Zebra Z4M plus printing an extra label
Restore factory defaults. If this doesn't sort it out, get back to me and I should be able to point you towards the right solution.
Mar 31, 2009 | Zebra Z4M Printer
Out of Paper Error
You get the error because the printer doesn't see any paper.
There are paper guides that need to be set for the size of the labels being printed. If you are switching from a 4" wide roll or sheet to a 3 1/2" label, you will have to move the slider in about 1/2". You will also have to calibrate the printer when you change label stock. If it won't calibrate, make sure the photoeye is hittint the break between labels. The photoeye is located where you insert the labels into the printhead path.
Feb 05, 2009 | Zebra Z4M Printer
Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
Jul 15, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4M Printer Logo
486 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
