External hard drive, how do I transfer to it?
  • butchs22 Jul 21, 2008
    i bought this external hd, hooked it up and nothing happened. What am I doing wrong?
    Novelist:
  • 88 Answers
You are probably not doing anything wrong - you just need to know where to look.
Assuming you are running a version of Windows, hold down the Windows key on your keyboard and then hit the "E" key. This should bring up Windows Explorer, showing all the disk on the left-hand side pane.
You should see your main system disk, the C: drive, and any other drives. Your new external drive should also be shown, probably as a D: E:, or F: drive, and will likely have the name of the manufacturer of the drive (e.g. Buffalo).
To copy files to it, click on the "+" sign to the left of the C: drive and then on any folders you see. The files in these folders will display in the right-hand side pane. To copy the files to the external drive, click on the file(s) on the right side and drag them over to the left-hand side on top of the external drive and release the mouse button.
To select multiple files, hold down the CTRL key as you click on them on the right-hand side, or if you want to copy a range of files, first click on the first file and then hold down the SHIFT key as you click on the last file. Then drag them over to the left-hand side.
Hope this solves your problem.
Posted on Jul 21, 2008
    Sergeant:
  • 320 Answers
If you using windows ME or newer the drive should show up under "My Computer" You can drag and drop files to it.
If the drive still has not shown up try these steps.
1. Make sure external drive power is on
2. If it came with software it may need to be installed first.
3. Plug in drive with computer off first. (usually not needed but may help)
4. Try the drive on another computer is possible to rule out faulty drive/usb adapter.
Some external drives require power from the computer, if this drive has no power adapter, you will want to ensure that you do not have a lot of other USB devices plugged in. You should hear a sound or get a message with the drive is detected.
Jei
Don't know to transfer my PC hard drive to my Seagate external hard drive (1T)
You can copy paste the contents or cut and paste or right mouse click on contents and click "send to....external drive" Once the contents is on the external drive this can be taken to another PC and copied back. Caution: Some contents can be very LARGE and take a LONG time to be copied! It is advisable to run a BACKUP every now and then. And be sure your external drive is working correctly (Scandisk).
Mar 27, 2013 | Computers & Internet
Can i transfer information to a mac
If the external hard drive has been formatted on a PC in NTFS file format then the MAC cannot read data off this hard drive.
The FIX..
Connect the USB external hard drive to a Windows computer and copy your data off this hard drive to the computer.
Then format the external hard drive in FAT32 file format. (the MAC can read and write to data to and from a Windows PC)
Now copy the your data from the computer back onto the external hard drive.
Now you can connect the external hard drive to the MAC and download your data to the MAC.
Feb 22, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
My Hitachi Touro 4TB external hard drive get stuck every time I try to transfer large files. How do I fix that? The format is NTFS and the files are 4g and up.
External hard drives are popular portable storage devices because they allow you to back up files such as documents, music and videos, and transfer files from one computer to another. While external hard drives vary in storage capacity, they are ideal for storing large files such as videos and animations. Files of this nature consume volumes of hard drive and memory space and are best stored in external hard drives. Whether you are using Windows or Mac OSX, transfer large memory consuming files to your external hard drive quickly and safely. Connect your external hard drive to your computer using the Firewire or USB cable that came with your portable storage device. If its transferring to slow the usb lead might be at fault or you might need a usb 3 card which makes data transfers much faster USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Power on your drive. Some external hard drives do not have a power button, because your computer powers them on automatically using the Firewire or USB cable. Click the Windows "Start" orb and click "Computer" or "My Computer" to launch Windows Explorer if you are using a Windows PC. You should see your external hard drive in the "Drives" section next to the "Local drive (C:)" drive. If you are using a Mac, you should see your external hard drive on the desktop. Double-click your external hard drive to open its hard disk window. If you have any content on your external hard drive, you should see it in this window. Drag files from your computer to your external hard disk's window. Because you are uploading large files, make sure their memory s do not exceed your drive's total memory. Your computer shows a status bar displaying the upload progress for each file you are transferring to your drive. The upload time varies depending on the of the file. Close the hard disk window when you finish uploading the files you want to store, and then click the "Safely Remove Hardware" icon on the System Tray next to the clock, if you are using Windows. The hardware removal window launches. Click your external hard drive's icon in the hardware removal window, and then click "Stop." When prompted, disconnect your external hard drive from your computer. Drag your external hard drive's icon from the desktop to the trash bin on the dock if you are using a Mac. Disconnect your drive from your computer. If you right click in the bottom toolbar select applications to see whats running at the time when transferring the files might be a virus or malware if you see something running that should not be select end now also processes to see what ticking over in the background
Hope this helps b>
b>
Dec 14, 2012 | Hitachi 4TB Touro Desk DX3 USB 3.0 Hard...
Does not allow transfer of files or pictures
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
Click on the "My Computer" icon on your desktop, and open the external hard drive.
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the photographs.
usually in my documents my pictures or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my pics 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the photo file, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
Sep 27, 2012 | SimpleTech Signature Mini 160GB External...
How do I transfer photos to the external hard drive
once the external hard drive is plugged in to the computer check under my computer is detected if it does
open the folder where or you can right click the folder or file you want to transfer then select the name of your external hard drive.
you can also use the software that came with your external hard drive but its much easier to drag and drop the files.
hope this help
Sep 07, 2010 | Western Digital Elements powered by WD 320...
How do you transfer data from this external hard drive to a new internal hard drive that was just installed
Turn your computer on. Plug the external drive. It should show in My computer window. Explore the external drive (by clicking on its icon in My computer). Point and select all you want to copy (CTRL A selects All) CTRL C. ( all that is selected will be marked for copying). Go to folder where you want to copy the files. Open the folder and CTRL V.
Hope it helps
Sep 07, 2009 | Computers & Internet
I can not transfer a file from the tri caster to an external hard drive
first save it in the local drive. then copy it to the external hard drive.because the computer cannot transfer the information to an external hard drive directly
Sep 02, 2009 | NewTek Tricaster Pro Live Production...
Windows easy transfer taken over external hard drive
back up your drive s data and use quick format ..it will not ask any further.
datarecoveryfactory
Aug 21, 2009 | Western Digital My Book Essential Edition...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
