Question about Movincool Office Pro 24 Air Conditioner
GFI plug trips when pluged in, no reset
When the portable ac unit is plugged in, the plug trips, when you push reset, the leds on the control flash and a quick bump sound is heard, the plug trips not the circuit breaker and nothing else happens.
  • 95 Answers
You are trying to draw too much power from the dedicated electrical line, or you may have an outlet that is needing replaced. Try to use another plug, in another room to test
Posted on Jul 21, 2008
REFRIGERATOR HAS STOPPED WORKING , NOTHING RUNS, NO LIGHTS NOTHING
If everything is dead the first thing you have to establish is that the unit is receiving electrical power. It is far fetched for every component to go bad at the same time!!!!!!
Jun 25, 2015 | LG LSC27910ST Side by Side Refrigerator,...
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
I have an Amana portable AC, Model # AP125D. When you turn it on, it trips the GFI. Can you help me. Thanks.
This indicates a problem of electrical leakage inside your AC and it should be inspected by an electrician for your safety GFIs trip due to an imbalance of current between the 'hot' and neutral lines which means that current in traveling from the 'hot' line through some path to the ground (safety pin on the plug). If you use any method to fool the GFI (there are some) you should anticipate having nasty shocks from any exposed metal on the AC; not good idea.
If a professional finds no fault, it is quite possible that the GFI itself is failing; I have replaced several which were tripping on insignificant events.
Jun 22, 2011 | Amana AP095R Portable Air Conditioner
This is the solution I rec'd earlier re my De Longhi Pinguino AC 10,000 BTU. If you're in San Diego CA could you make a house call to fix my AC by replacing the cord/plug?\r\n The portion of the plug that...
Never remove a GFI. It is there for a reason. If your plug is has a bad GFI, you can replace the plug with a standard one but make sure you replace where it plugs into with a GFI receptacle which only cost about 30 bucks, or you could replace the breaker that feeds that circuit with a GFI breaker. The problem with replacing the breaker is that if you place any resistance head loads on it (i.e. blow dryer, toaster), it might trip because you get a loss of current from resistance heat. The GFI only looks at what is going in and what is going out. If it sees an imbalance of up to 20 milli amps, it will trip. Your cheapest way is replace with a standard plug and add a GFI plug receptacle to where it plugs into.
Sep 27, 2010 | DeLonghi Heating & Cooling
My Reset button wont reset
Just guessing, here. The reset is actually a "Ground Fault Interrupter" called a GFI. It's there to cut of power in case of a dangerous electrical condition--which you probably don't have.
Did you unplug the unit? If not do so, let the GFI cool for several minutes, and try to reset again. They're pretty hard to push in, maybe use a fingernail, you must hear a click or it's not reset.
Is there water in the outdoor unit, or is it filled with snow? This is the most likely cause of an actual GFI fault.
If the GFI itself has failed (unlikely), you could replace the entire power cord. You should then maintain safety by installing a GFI circuit breaker on that circuit, or you'll be in violation of codes that might affect your homeowners insurance.
There could actually be a problem with the unit. This would be that an electrical wire has come loose and is contacting the metal chassis, creating a shock hazard. Unlikely but possible.
If the receptacal you're plugging into is old and worn it might the problem. Worn receptacles might actually have tiny electrical arcs inside, which can trip a GFI. At a couple of bucks (DIY) it's worth a shot.
If there's actually an electrical fault in the unit it can be found and repaired, but the cost of repair could very well be more than it's worth. Warranty?
Mar 27, 2010 | LG Electronic Window Air Conditioner
Kicks off imediately ground faught on karcher pressure washer
This is a serious situation. It means there is a short circuit somewhere. You need to have a certified technician or electronics person look into it.
Aug 21, 2009 | Karcher 1750 psi Electric Pressure Washer
My LG window ac continues to shut down after 20 or 25 minutes
The button on the plug is a GFI. Ground fault interuppter. Like on your hair dryer. When the unit is running, or has just tripped out, feel the plug and the well receptical. If either feel warm or hot, do not continue to run the A/c unit. Get an electrician to check for a faulty/ worn/improperly wired outlet. The units tripping out for a reason.
Aug 01, 2009 | Samsung AW0603B Air Conditioner
Movincool Office Pro 24 Air Conditioner Logo
386 people viewed this question
Top Movincool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Movincool Heating and Cooling Expert? Answer questions, earn points and help others
