Portable dvd will not play anymore. It keep on reading code H03
  • 5 more comments
  • Anonymous Jul 26, 2008
    DVD wont play HO3 code
  • iancsimpson Oct 05, 2008
    Panasonic DVD-LS80 error code H03
  • bowlingdave1 Dec 26, 2008
    where do i find the laser in the ls91 dvd player
  • Anonymous Jan 14, 2009
    code h03
    problem code error HO3
  • Anonymous Mar 19, 2009
    Just all of the sudden stopped playing and displays Error H03. AgHHHHHHHHHHHH! What to do?
  • snarsnisse Mar 21, 2009
    it appears suddenly while viewing a dvd. Error H03. I turn it off and then on again and the same error message appears
Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Posted on Sep 23, 2009
What does error H03 means af the Philips portable dvd PD9030?
Go to this link http://tech.rickumali.com/blog/2008/12/30/fixing-my-portable-dvds-h03-error
Aug 06, 2016 | Philips PD9030 9" LCD Portable DVD Player...
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Player will not read. Error code H03 shows up on screen.
Dirty worm gear on laser (dirt or particles got caught not letting the pick up move easy go take apart but be careful many small screws and gears.
Oct 06, 2009 | Panasonic DVD-LS91 Portable DVD Player...
Player does not read disc-code HO3
I followed a few, of the already suggested answers. The first one I tried was to open up the back and use compressed air to blow out lint, food crumbs and dog hair that had found there way into the machine. This seem to have worked just fine. Now the machine is working, much to my daughters delight.
Sep 29, 2009 | Panasonic DVD-LS90 Portable DVD Player
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Portable DVD player won't read discs.
There are 2 errors, ho3 and ho2, I can't remember which one is which. One means the laser is going and one means it's a dirty track. I suggest you first very gently clean the lens. If that doesn't work you take apart the player and clean the whole track that the laser moves on along with everything around it (keeping in mind that the laser is fragile). If that doesn't work than I can't help anymore without seeing it.
Mar 31, 2007 | Panasonic DVD-LA95 Portable DVD Player
Error H03
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Jan 06, 2006 | Panasonic DVD-LS55 Portable DVD Player...
Televison & Video Logo
553 people viewed this question
Top Televison & Video Experts
Electro Med Services...
