Question about Broadcom Computers & Internet
Broadcom 802.11g stop recognizing any wireless on my gateway laptop
Just like that, eventhough it says is workig properly
  • c 47tp Jul 24, 2008
    Amazing how ignorant one is even with simple stuffs!
This is a known problem with hp/compaq machine it is listed on there support page as a recall to fix solution
Posted on Nov 06, 2008
    Sergeant:
  • 287 Answers
Is this on a laptop? check that the wifi is not turned off. some laptops have a switch on the side or perhaps a Fn key (blue icons on the F keys) that disables the wifi on the pc. try Fn+F2 or Fn +F5 (look a the F keys for a blue wifi icon)
post back results and the system you are using inc the OS so I may assist in greater detail if required
Posted on Jul 22, 2008
  • Dave Jul 24, 2008
    dont be to ******* yourself... it's often the "simple" things we miss. I did a similar thing recently.... :-)
    glad I could assist
While playing my organ it stopped working but the foot pedals are workig. finee
You should probably post your question in the proper category. Most likely, an answer will not come from the sewing machine category.
Feb 02, 2017 | Sewing Machines
Fridgedaire glrs 237 za autodefrost not workig?
Hello friend, thank you for your inquiry!
It sounds like you could have a problem with your defrost timer or control panel. I would recommend having a professional come out to your home to properly diagnose and repair your appliance to avoid any unnecessary part purchases.
Sep 10, 2014 | Frigidaire Refrigerators
Driver for broadcom bcm943225hm wireless adapter, i can't find it anywhere...
here are the drivers for your laptop, the broadcom is at the bottom of the list.
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=3234
Mar 01, 2013 | eMachines E528 E728 Intel Laptop...
Gateway 600yg2
I may not be understanding what you are stating, so bear with me;
1) The Wireless Modem antenna wires are up in the Display Assembly,
http://www.mundocorp.com/shopexd.asp?id=1160
In otherwords they should already be there.
2) The 802.11 Mini PCI Card, is a Wireless Module.
It goes in the Mini PCI Compartment, under the Mini PCI Compartment Cover, located on the bottom of the laptop.
It's made by Broadcom,
(Gateway 6002672 part number)
http://support.gateway.com/s/Mobile/NETWORK/Wireless/6002672/6002672mv.shtml
See at the Top right where it states Main, and has a white Side Arrow?
This terminal is where the Black wire (Lead) of the wireless antenna connects to.
The other terminal, AUX, is where the White wire connects to.
http://www.laptops-we-r.com/prestashop/gateway-6000-parts/418-gateway-dell-broadcom-bcm94306mp-b-g-mini-pci-wifi-card.html
Here is the Service Manual, (PDF file form),
http://support.gateway.com/s/Mobile/Gateway/600YG2/8508798.pdf
Page 13.
REMEMBER, remove ALL power. Remove the AC adapter (Charger), and Battery, before working on the laptop. Also follow Anti-Static Precautions.
Regards,
joecoolvette
Aug 20, 2012 | Gateway Computers & Internet
When i start my printer its display the scanning error 20 on display screen....scanner is not workig but printer is still working propely ...my printer model is mf1005 hp laser printer...please give proper...
The proper solution is to send it in for service. You arn't going to be able to replace the copy/scanner assembly without the proper training or parts.
Aug 22, 2011 | Office Equipment & Supplies
My Gateway MX3225 laptop is not detecting my wireless adapter. Every time I click the Broadcom Wireless Utilities icon it opens to 'no adapters'. I recently reinstalled my operating system XP and...
Start>Control Panel>Administrative Tools>Services>Make sure that "Plug and Play" and "Wireless Zero Configuration" are started (double-click startup type and change to automatic, then click start under "service status")
Aug 03, 2011 | Computers & Internet
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
Computers & Internet Logo
543 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Computer Links
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
