Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
You seem to know this camera pretty well. Can you help?
This camera seems to work when it wants too, but sometimes when I go to turn it on it just has a blank screen and the lens doesn't open. Then after a minute or so it will say "check connections" and then turn off. On top of that, when it does work, it will always ask me to re-enter the date, time, ect... The camera typically seems to work more often indoors as opposed to outdoors/in my pocket. Sometimes it will randomly do the blank screen thingy after being on and working fine for a minute. Pulling the battery out for a while doesn't fix the problem.
Thanks for the help!
  • 374 Answers
Is it saying "check connections" when it's connected to a computer or no?
If it's saying that when you don't even have it connected to a computer then we have a definate problem. If it does it when you are just trying to take a picture then you are going to have to send it in and have it fixed because there is a problem with the gears of the lens.
When it does work and it makes you re-enter the date and time all the time there is something wrong with the internal memory. That is also something that repairs would be able to fix for you. If you still have some warranty left on it they should be able to fix it for you.
Hope that help. :)
Posted on Jul 22, 2008
Will resetting my camera make the buttons work again? Is there a way to reset the camera without going to the menu (since the buttons don't work)?
Only the two buttons on top of the camera. It looks like you have a real problem. All buttons on the back look dead.
Reset of a camera is done every time you switch it on, so that will not bring any difference. One step up is removing the battery for a few moments, bit when the error keeps coming back, I think someone must have dropped the camera once, or some moisture came in the camera, and did something with internal connections.
When nothing helps and you did not drop the camera, check if it is still under warranty and contact a Olympus certified service centre.
DOn't send it in unless you know what it could cost. Sometimes repairs are more expensive than a new camera.
Jan 28, 2015 | Olympus Vr-340 16mp Camera Digital Optical...
The camera was working fine. I imported the pictures to Picassa succesfully and turned the camera off. I then went to take new pictures and all I get is a black LCD screen and when I load into Picassa the...
The CCD is bad or the Iris is shut stuck. If it's the Iris just stuck, it might just have moisture - leave the camera in a dry place for a day. If it's the CCD - pretty much "kiss-it-good-bye". To replace the CCD is expensive - get a new camera.
Nov 02, 2010 | Cameras
I can't seem to get my insignia digital camera to turn on
I have 5mp Insignia cam some days before I on my cam.I saw cam is on but no display on lcd pleas solve my trouble.
My Email address is
zarar70@yahoo.com
Thanks
Apr 16, 2010 | Insignia NSDSC7B09 NSDSC7P09 Digital...
I own a Canon power shot SD790 IS and I've been using wonderfully for the past few months Last weekend when I turned on my camera to view some pics I noticed a little blue screen on the corner of my camera...
It seems to be a dead pixel, best thing would be to have it replaced from the Seller, else you can get it replaced with a new working lcd panel. This may be an expensive solution.Check whether you have a worldwide warranty from Canon, that will help you on saving costs.
Jul 25, 2009 | Canon PowerShot SD790 IS Digital Camera
Lens error and camera battery not charging.
SORRY TO SAY, BUT I AM READING HORROR STORIES ABOUT THIS MODEL OF CAMERA AND IT'S CHARGING OR LACK OF CHARGING SYSTEM. IT SEEMS IT IS A MAJOR PROBLEM WITH THE M853 AND ABOUT THE ONLY SOLUTION PEOPLE ARE FINDING IS USING A SEPARATE CHARGING BAY. IT SEEMS THAT VISTA HAS A POWER MANAGEMENT SYSTEM ON USB PORTS THAT TURNS OFF THE POWER ON UN-USED USB PORTS AND THAT IS WHY THEY ARE NOT CHARGING. YOU NEED TO GO INTO THE USB PORT SETTINGS AND RIGHT CLICK THEM AND DISABLE THE SETTING THAT ALLOWS THEM TO SHUT DOWN POWER TO THE USB PORTS. IT ALSO SEEMS THAT THERE IS A LOT OF TROUBLE WITH THE MAIN BATTERIES IN THE M853 FROM THE VERY FIRST TIME YOU TRY TO CHARGE THEM. THEY SEEM TO NOT WANT TO TAKE A CHARGE. I KNOW ALL THIS IS BAD NEWS BUT GO TO GOOGLE AND PUT KODAK EASYSHARE M853, NOT CHARGING AND READING THE STORIES FOR YOURSELVES. THEY ARE NOT PRETTY. BEST ADVICE I CAN OFFER IT SEEMS IS SEPARATE CHARGING STATION AND DEDICATED USB PORT YOU KNOW IS HOT. GOOD LUCK ON THIS ONE. IF THE CAMERA IS FAIRLY NEW, I WOULD CONSIDER RETURNING IT! THIS ONE HAS A REALLY BAD TRACK RECORD. IF I CAN HELP MORE, REPLY TO: ARCLIGHT1217
Nov 05, 2008 | Kodak EasyShare M853 Digital Camera
Camera turns on and then off
Sometimes this happens when the batteries are low. These cameras seem to use up battery power pretty quickly. You might want to try using rechargeable "hybrid" batteries.
Oct 25, 2007 | SVP CDC-8680 Digital Camera
Power on, buttons off
ALWAYS USE ALKALINE BATTERIES. RECHARGABLE
ONES JUST DONT WORK .
Sep 27, 2007 | Aiptek PocketCam DV4500 Digital Camera
Memory Stick Error
memory connector in camera may have loose or corroded pins ( memory card will not seat ) ; consider replacing connector - if cleaning and resetting connector pins does not help ;
Aug 01, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
F10 - turn LCD off?
Oh well, as disappointments with gear goes, that's a pretty minor one.
Aug 30, 2005 | Fuji FinePix F10 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
51 people viewed this question
Top Casio Cameras Experts
Fred Block
Fred Block
Are you a Casio Camera Expert? Answer questions, earn points and help others
