Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Freezer leaking The water is coming from the bottom of the freezer. It happens intermittenly....every day to once a week. We recently moved the freezer (April of this year) and it has done it every since.
  • Gary Davd
    Gary Davd May 11, 2010
    too bad you rated me so crapy maybe thats why you are getting no help from anyone !!
  • 639 Answers
Hi Cliff Claven,
Happy to help.
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
May 22, 2017 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Water on freezer bottom. I have a Maytag refrigerator, side by side, Model MZD2768GEW, seven years old. Recently I have found about 1/3 cup of frozen water on the freezer bottom. It is not comming from...
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Maytag Freezers
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Fisher and paykel e521t icing issue
should be a hose going down to drain pan, check it, could be plugged, or compressor on way out an controll not workin prop.
Jan 04, 2010 | Freezers
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Small upright freezer (4 cu ft) is leaking water
Could be just the coils are iced up, I would pull everything out of it, unplug for a day, plug back in and let it run....
Aug 22, 2009 | Freezers
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Freezer leaking water
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 09, 2008 | Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
77 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
