Question about GE WBSR3140DW Top Load Washer
Oil and black specks on floor underneath washer (middle)
I pulled out my 1991 GE washer to clean and found a small (2" dia) puddle of light colored oil and some small black specks in the center of where the washer is located. What is this a sign of? What do I need to do?
  • francharles Jul 21, 2008
    Not enough detail as to where the oil and specks are coming from.
  • Anonymous Feb 11, 2009
    oil
    Sergeant:
    Champion:
  • 330 Answers
Check the position of the oil mark and check your machine to find out which place was leaking and fix it, maybe you need tie the screw up a little bit.
Posted on Jul 21, 2008
  • Frank Chen Jul 21, 2008
    use a tissue papper and clean the bottom of the motor, just touch it, you have to use this way to touch many places and see if you can find leaking place, otherwise, don't worry, maybe when the motor is running hot, the grease milted.
    If you find somewhere with light oil, you must tie the screw.
Frigidaire washer and dryer stackable set leaked oil on floor What do you think this could be?
The only thing that could have leaked oil out is the actual transmission of the unit. You are going to need to consult a professional technician for further repair and assistance. You might want to get a repair estimate and weigh your options of repairing versus purchasing a new Frigidaire unit with a manufacturer's warranty.
Jul 19, 2012 | Washing Machines
After driving home from work, found a huge puddle of oil in my garage floor, ( apparently it happend that morning ), Checked my oil, none on the dipstick ! There is oil all over the coolant bottle,...
if it is coming from up top it might be the cam cover or the seal at the front-put in enough oil to read it on the dip stick and start it up, if it is that bad it should be obvious
Feb 17, 2011 | 1995 Saturn Sl
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Oil leak under washer
if its an old ge it needs a transmission seal
Apr 24, 2009 | Washing Machines
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Leaking on the floor on "small load" setting only
I have been selling and been doing factory authorized service on GE for nearly 30 years. I have sold many of this model. It's hard to imaging that a machine would leak water on small loads but not larger loads. In a case such as this, a servicer must remember to test the machine exactly as the home owner is using it. I would take pull the machine away from the wall and adjacent cabinets and dryer if hoses permit, (so that I could rule out water coming from somewhere other that the washer) remove the front panel, and have the home owner run the exact cycle with the exact settings and the same clothes load and soap used when the machine leaked. I suspect that some water is splashing over the wash tub. If you use a gentle cycle or a larger load you get less splashing. Even having a few more cloths items in the machine would reduce splashing. You might not expect a solution, but you do deserve an explanation. Some times the solution is strange, for example: I had a customer who said the washer leaked a lot of water onto the floor the first time it was used in the day, but worked great the rest of the day. I came out early the next day and tested the machine, and it did exactly that. What happened was the builder added on this new laundry room and the drain pipe went through the floor before the plumber added the trap. The builder then insulated the area but put the insulation on the room side of the trap, allowing cold air to freeze and plug the drain. After warm water pumped into the drain and most of the water overflowed the top of the pipe onto the floor, the rest of the water melted the ice in the trap and the machine worked fine until the next day after the water had a chance to form a later of ice in the trap again. The fix was simply to move the insulation to the other side of the trap. (OK, here in Minnesota we run into weird things like that, but my point is to test the machine exactly as it is used to find where the problem lies) I'd like you to post a comment when you find your solution.
Nov 02, 2008 | GE WDSR2080D Top Load Washer
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Small lines or specks on the right side of every page
Did you try cleaning the lense? You'll have to pull all the toners and open the little door below and wipe with a clean lint free cloth in ONE direction.
Nov 10, 2007 | Lexmark C510 Laser Printer
GE WBSR3140DW Top Load Washer Logo
176 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
