Question about Pentax Optio M20 Digital Camera
Camera was dropped
I dropped my camera and it got slightly wet. Dried it off, removed the batteries and let it sit for 24 hours. It seemed to work just fine except now that I have attempted to download my pictures I get this message:
"Unable to connect with USB and Imagelink simultaneously. Disconnect all interfaces"
I have disconnected the USB cord and replaced the batteries, re started the computer...is there something I can do that will work?
Thanks in advance.
  • 56 Answers
This is probably a Technitians job, But you are VERY lucky that further damage was'nt done!
The Best advice is to get an SD card reader that the memory card can plug directly into and this will then plug via USB, and come up just like a USB stick. You'll probably find it is faster than the software too.
Posted on Sep 11, 2008
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
My daughter spilled juice on her cell phone, it can receive calls but she cant answer them because the touch screen will not work
You should never turn on any electronics that are wet.
  • Remove the battery
  • Place phone in a bag of rice
  • let it sit for 24/48 hours
  • Replace battery
Once it has dried out from the rice, you should be good to go, if you have not damaged it by powering it up while it was wet
I hope this helps
Magoo
Mar 11, 2011 | Cell Phones
A samsung phone got wet an everything seems to be
There is probably corrosion due to the liquid damage on the circuit board. You can try cleaning it with an old toothbrush and some denatured alcohol. If that doesn't work, then it probably shorted out the RF ic. This would have to be replace by your local repair shop.
Dec 09, 2009 | Samsung Eternity Cell Phone
Sidekick lx 2009 3G
Try this : This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Sep 03, 2009 | Sharp Sidekick LX Smartphone
I dropped my Canon EOS Rebel Xti in the canal while kayaking.
Water in the camera body could take up to a week to dry. If you tried turning it on while it was wet inside, you may have shorted out some circuits.
Aug 23, 2009 | Canon EOS 400D / Rebel XTi Body Only...
Samsung Glyde water damage.
try this :
it sounds crazy .
Jun 08, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Sony handycam got wet now wont recharge or work off batteries dcr trv 270
you can try removing everything you can remove from it, i,e battery and anythig else detachable.
Place it in a warm dry place for 24 hours. Airing cupboard, on top of or near a radiator ( wrapped on on a towel to avoid direct heat.
then open the dvd drive door, and gently blow warm air into it with a hair-dryer ( medium setting )
try again after it,s thoroughly dried out.
replace the battery, and try again.
If this does,nt work, i,d suggest buy a replacement, or make a clain on your insurance, for contents if you have one.
Mike @ compurepair.
p.s it,ll cost more to repair, than to buy a new one, and never be the same camera again.
good-luck Mike.
Feb 25, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
My camera got wet. Help!!!
Has it dried out yet? The images on the card, as I;m sure you know, were fine.
Aug 22, 2006 | Fuji FinePix E550 Digital Camera
Pentax Optio M20 Digital Camera Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
