The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone: Start with the headset powered on. What is the pairing security code for xx3 - m1500.jpgnd hold down
the call control button while also rotating the multi function dial
upward (away from the light) until the indicator light on the headset
starts flashing red then green. When prompted for passkey, enter
0000.
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the
headset is in "Pairing" mode you will then need to follow the
instructions in your cell phone or Bluetooth device's user guide on
how to go it to your phone and search for the headset & pair it to a
Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and
the talk button at the same time. Hold them in together until the
indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
What is the pairing security code for xx3 - 320_128.jpguploads/images/320_128.jpg" alt="320_128.jpg" class="h_mi" />
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver
call control button in for 6-10 seconds. The light will flash blue
first. Continue to hold the button down then release the button when
the indiWhat is the pairing security code for xx3 - dis655_128_blue_pop.jpghing red then blue.
Plantronics 655, 665
firWhat is the pairing security code for xx3 - discovery645_small.jpghe button down then release the button when
the indicator light starts flashing red then blue.
Plantronics Discovery 640, 645, 640e
call control buttoWhat is the pairing security code for xx3 - plantronics-590a_small.jpg light will flash blue
Plantronics Pulsar 590/590e & 590A & a BlWhat is the pairing security code for xx3 - pulsaradapter.jpgr />
Begin with the headset turned off. Press and hold the call control
button then power the headset on and when the indicator light flashes
red and blue, release the call control button. Once the headset is
paired successfully the headset will flash blue.
For the Plantronics Pulsar 590 & 590A & the Universal Adapter:
button. Power the headset on and when the indicator light flashes red
and blue, relWhat is the pairing security code for xx3 - pulsar_260_128.jpgrol button. Turn the Universal Adapter
on. Press and hold the adapter pairing/connect button for 7-10
seconds. When adapter starts flashing red and blue release the
buttons. The headset and adapter will flash blue when paired
successfully.
Plantronics Pulsar 260
For the Plantronics Pulsar 260, Begin wiWhat is the pairing security code for xx3 - m2500.gift powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant
is flashing red and blue, use the phone menu to search for Bluetooth
devices and select "260 Plantronics." When prompted for passkey,
enter 000What is the pairing security code for xx3 - m1000.jpgbr />
For the Plantronics M2500 (discontinued):
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter
(discontinued): Turn the headset on and the adapter off. On the headset
push in and hold the mute/volume dial until the indicator light begins
to flash. On the adapter press and hold the blue power button for 10
seconds. The light on the adapter will flash once after 3 seconds-
continue to hold the power button for another-7 seconds until the
light flashes red. If the pairing is successful, the headset will
sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued):
If you remove the battery cover from the headset and then remove the
battery itself. On the Green PC board itself there will be a letter
followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
