Here's the setup, Intuos3 6x8 connected to Dell laptop running windows XP SP 3 Wacom Driver 6.1.6-7. Laptop screen resolution is 1024x768 but the cursor won't go down far enough to hit the taskbar or start button, even though the pen is at the bottom of the pad. Tablet properties seems to think the monitor is a widescreen? With no option to adjust. Help?
I might not be necessary to reset to factory settings. Just go to the Toshiba.us support site and download the drivers for the Tablet PC (that includes the WAcom driver, all the tablet PC extensions). If you have the Recovery CD, you can run it from inside Windows XP and reinstall selectively all you need. Just to set things straight, the screen of the R15 reacts to the Wacom pen only, not to your finger or some other plastic tipped pen.
There is no Fn-Fx key combination to change screen resolution (at leat on my R10 running Windows XP. Even if you create a shortcut to open the graphics properties you still have to open the relevant tab manually to change resolutions. You can open the Intel Extreme Graphics 2 for mobile icon on the tray, go to the graphic properties change the resolution and save as a scheme. With a customized scheme defined you will be able to click the Intel Graphic properties and select that scheme. But be careful, your tablet pen will no longer be calibrated with the available screen area. I tried on my R10 (native resolution 1024x768) and all I could select was 800x600@ 60Hz.
you need the wacom touch screen driver, just go to wacom .com and all i did was download and installed the driver, i run win xp , not tablet version, and after the driver ws installed the table an pen worked 100%,
If you are getting a Blue screen repeatedly and you can't start up to
windows in any custom setting ( from f8 start up menu ) one way to
solve the problem is to Use the restore disc or windows installation cd
or dvd to install
windows into the computer or perform a repair installation if a windows
already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When
the Press any key to boot from CD message is displayed on your screen,
press a key to start your computer from the Windows XP CD.
if
not then the computer is not set to start up from a cd, you can either
enter the setup / bios to change that setting OR right when you power
up the computer look at the screen it will say what button to press in
order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones
windows is working you will need the drivers for your computer, they
are at the makers website, for hp and compaq. www.hp.com for acer
http://support.acer-euro.com/drivers/downloads.html for all other
brands go to google and write Brand drivers. Should get you to the
right place. Dell is most likely www.dell.com and so on.
If you have run the laptop in safe mode it uses the standard VGA graphics driver, and this indicates the onboard graphics card is still functioning. Try connecting and external monitor to your laptop and the boot up your laptop. Then :- 1. Download the latest graphics driver from ASUS WEB site. 2. uninstall the graphics driver. 3. Reboot the laptop and install the new graphics driver. 4. Shut down and remove the external monitor and reboot. 5. Goto the Control panel - Display and check/set the settings for screen resolution, Colour setting etc.
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Problem fixed by downloading/installing an older driver.
