Question about TruTech PVS31170S1W 17 in. LCD Television
TV does not turn on
Even with new batteries the rtemote doesnot turn on the TV. The red sensor light is on on the TV.
  • 3 more comments
  • Anonymous Nov 26, 2008
    My remote does not work at all.
  • Eugene Waage
    Eugene Waage Nov 30, 2008
    tv does not come on at all
    i fell asleep and when i woke up i could hear words but there was just a few lines on the tv
    after unplugging it and getting it back on there was no lines and no sound and then eventually the tv screen just remained completely black instead of that light grey color it turns when powered up
    i've only had it for three years its not that old
  • Anonymous Dec 03, 2008
    remote stoped working, even with new batteries tv in only 10 monthes old.
  • Anonymous Jan 27, 2009
    Remote does not work - how do you get a new one?
  • computerwiza Feb 16, 2009
    tv does not respond to remote camands.
Help
i need trutech remote codes
Posted on Sep 27, 2008
Which part of the board is defected? where could i find this def capacitor
Posted on Sep 21, 2008
    Master:
  • 382 Answers
Please try to check With your Remote..may be its time to get new remote as the sensor or chip in your remote might not be working!..
Posted on Jul 21, 2008
  • Natesan Sabesan
    Natesan Sabesan Jul 21, 2008
    If some of your friend has the same remote please try to test with that remote!..Please post back how things turned on or for further assistance..THank you!..
    Regards!!..
  • 6,487 Answers
Is there a way to run the TV on without the remote??
    Guru:
  • 1,894 Answers
How many times does the red light blink?
  • 1 more comment
  • dewan nafees ahmed Jul 21, 2008
    the red light must blink in some particular pattern. please note the pattern
    if manual switch is present use the manual switch to switch ON the unit.
    if it does not turn ON even then it is some internal problem in power board of your UNIT.
Palsonic 32" model TFTV326FHD, remote sensor light just keeps flashing red when you try to turn on TV with remote. We tried new batteries, unplugging TV, other connections fine, but TV wont switch on.
The "remote sensor light" is the power indicator and it is blinking to let you know either an internal fuse is open or the power supply has failed.
Jan 16, 2018 | Televison & Video
I reset my Panasonic DMR-EZ45VEBS to default and since then I cannot set it up again. The remote control doesnot react and I have checked the batteries !
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Dec 25, 2014 | Panasonic DMR-ES30HS DVD RECORDER and VHS...
1999 ,4x4,454,2500suburban.airbaglight stays on,when truck is turned off something is draining the battery ,the clock doesnot work fuel gage doesnot work.
Sorry to say, but none of these are related. Fuel gauge is probably the sending unit in the tank, could be wiring. The air bag could be the module,the bag unit, the sensors, or bad wiring. The radio is probably your most likely choice for battery drain. The three main things I have found to drain batteries are the radio, the starter, and the alternator. These three will kill a new battery in 1 to 2 days, An older battery over night. Shorts in the interior lighting is 4th..
Apr 05, 2014 | Chevrolet Suburban Cars & Trucks
Remote control not working brand new sony rm-lj301 remote
Check the remote control for its infra-red emission. Even new pieces might have the fault. You can check its infra-red emission, by a mobile phone having camera option. If you wish to get more details about how to check a remote control, check this link.http://electronicshelponline.blogspot.com/ If the remote control emits infra-red emission, and still TV do not respond to it, the fault will be due to a damaged infrared sensor inside TV. This part can be located just behind the infrared window at the front panel of the TV set. You have to open the TV, to access it and to replace with a new one. The part will look somewhat like these.
Jun 11, 2013 | Televison & Video
Even with new batteries the remote is making no connection with the TV. Can it be fixed?
If you already replace the old battery try to check the battery terminal the one that is solder in the pcb, try to check the leads that holding the battery terminal if loosed, Then if battery terminal ok, Try to check IR LED sensor of the remote you should have camera or cellphone with camera then try to point the IR LED sensor to the lens of the camera and press any button then look at the monitor of the camera if there is a red light that is glowing if you see this red light it indicates that your remote is in good condition. Good day.
Jul 13, 2011 | Hitachi Televison & Video
Battery in charger overnight, red light flashing, insert battery in drill, it doesnot work. Please advise. Thanking You Bob Falzano
If only the red light is flashing then the battery is not charging at all. Ryobi identifies in the manual that batteries will not charge below 43 degress F. If your batteries and charger are in the garage in a cold climate, warm the batteries to room temp in the house and then try again. If the charge starts when the batteries are warm they will continue charging for the full cycle even in a cold area.
Dec 24, 2010 | Ryobi Multi-Volt Battery Charger
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
My dell latitude d600 won't boot even with battery out or in or p
Can you enter to Bios? if it boot and doesnot load to windows, could be your windows is corrupted or your hard drive is died, but if it doesnot boot at all, this could be not enough power.
Oct 14, 2009 | Dell Latitude D600 Notebook
LCD tv power light doesnot come on.
These off brand almost always have power supply issues that have to be troublshot. $150 at a local tv repair.
Nov 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
TruTech PVS31170S1W 17 in. LCD Television Logo
158 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
