Question about RCA P52921 52" Rear Projection Television
RCA p52921 I have a rear projection TV RCA P52921 and am having the biggest problem connecting a regular vhf/uhf antenna to the tv and getting any kind of reception at all. Very frustrating--can you help me please.--Thanks--Carrie
    Problem Solver:
  • 17 Answers
You will need to connect your antenna and do an auto search. When the search is over you might have to choose the broadcast option over the cable selection. That might bring in the picture.
Posted on Oct 03, 2008
P52921...TV was dead. I turned it off last night no power this morning small fuse was blown and I replaced it and cleaned very dusty lens and hard reset. Now TV is not showing on entire screen but has a...
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resistors,must be change to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 28, 2010 | RCA P52921 52" Rear Projection Television
RCA P52921 changed channels by itself and unplugged it to reset it and
Take batteries off the remote and check if it is the remote , otherwise it is a stuck key on the tv or the control board is gone,
regaards
Mar 31, 2008 | RCA P52921 52" Rear Projection Television
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
Mr rca rear projection tv just came on last night on it's own. i can now only power it on by the front power button. tv has no response to any other buttons on front console and no response to remote.
hi,you need to replace the front control panel, 1 or more of the tact switches have failed, if your proficient at solder work you can replace the switches, if not replace the small board behind the front buttons, available from any local tv shop just bring them the complete model # of your tv, gl, video-tek
Jun 04, 2009 | RCA P52921 52" Rear Projection Television
Rca P52921 52 in. projection made apopping noise
sounds like possibly the high voltage amplifier' just a guesas
May 08, 2009 | RCA P52921 52" Rear Projection Television
I have an rca antenna model ant110. & i don't get where/how to connect the uhf part [round metal piece] the picture on line is not clear & we do not have the box it came in. thank you
You will need a Vhf/uhf combiner to attach to the antenna to new TV's. Check with your local TV repair shop, they should be readily available.
Dec 17, 2008 | Televison & Video
My tv has sound but no picture
Check to see if you aux inputs pass the audio and video. If you see picture and have sound then your problem is most likely the tuner.
Jul 06, 2008 | RCA P52921 52" Rear Projection Television
52 in. rca tv model p52921
DO not have set fixed file insurance if you have it! this set can cost more then it is worth.Save your money buy a new one.Thankyou for using FixYa. Have a Nice Day.
Nov 08, 2007 | RCA P52921 52" Rear Projection Television
Big mistake
what was the origonal symptom before replacing the flyback? You could try using epoxy on the wire get a nice size glob of it on there where the wire got cut.
Jan 17, 2007 | RCA P52921 52" Rear Projection Television
56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
RCA P52921 52" Rear Projection Television Logo
115 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
