I dropped my pc and it wont turn on - Computers & Internet
    Sergeant:
  • 320 Answers
Hello my name is Jei and I hope the following helps you out.
Please read all the way through before beginning.
Pre-step, check if its under warranty if so, take advantage of it.
First off you will want to make sure you have a clean area to work in.
Second remove the side of the case with the computer laying motherboard down. Inside you will see a lot of stuff but don't worry as long as you take your time and have patients you'll be fine.
Before touching anything inside the computer place one hand on the metal part of the case, This will ground you from static.
Next look for a plastic connector whos wires lead up-to the power supply unit, This is usually a 24 pin connector. Squeeze the small clip on the side and pull it firmly (Do not yank) out of the socket, you may need to wiggle it gently to get it to losen. Once the connector has been removed firmly press it back into place. This will ensure the connector is making good contact.
Next you want to look and make sure all other wires are firmly inserted into their respective connections. Press gently down on the cables leading to the drives, if they are SATA connectors they will be thinner and usually connect to smaller blocks on the motherboard, gently remove and re-connect these too.
Now the fun part. Again make sure you ground your self before doing this.
You'll see some small sticks standing off the board. These are your ram. on each end you'll see a small clasp/lever press these gently away from the ram stick and one end should lift up slightly. Do the same to both ends (Do not pull ram out when only one end is free). Once both ends are raised and the clips are out of the way, grab the middle of the ram stick and lift it up out of the slot. Check it for any damage such as cracks. If all looks ok insert the ram into the slot and firmly press down on both ends evenly. You should hear a small clicking sound when the clips lock into place. Repeat this for each stick or ram grounding your self before and after removal.
After all this is done take a flash light and look around the board (Not touching it) for damage such as cracked or broken parts. Pay close attention around where the screws hold the board to the case.
This is also a good time to blow the case out with some duster or other air certified/designed for computers
If all looks fine put the side back on the computer, plug it all ine and try to turn it on.
If nothing happens you could have several things.
Broken/damaged motherboard
Broken/damaged RAM
Damaged Power supply.
Each part will have to be tested seperatly by someone with the correct tools, This would be where I'd recommend taking it into a professional.
If the computer is still under warranty, take advantage of it before opening the case.
I hope this helps you out in some way.
Jei
Posted on Jul 21, 2008
    Novelist:
    Scholar:
  • 160 Answers
Check the "rocker" power switch at the back - make sure it didn't get set to "Off" or zero.
Open the case and be sure all the cards are seated firmly, and that no connectors have come loose.
If the lights come on after powering on but the disk drive doesn't start, you may have damaged the hard drive. It may not be repairable, and you might lose your data. I hope that's not what happened.
Let me know how these suggestions worked out for you.
Good Luck
Airoff
Wont turn on
Just a query, has the laptop been dropped? If so it may have damaged the internal hard disk drive. If it has not been dropped, can you boot in safe mode?
Jan 29, 2013 | Dell Inspiron 1545 Black Intel Celeron 900...
Fan won'tt work and computer wont turn on
Laptop abuse, your luck it will work at all. It sound like it's done. You may have killed it
Nov 04, 2012 | Compaq Presario CQ56-115DX Laptop
My daughter dropped her laptop now it wont turn on and keeps saying theres a hard drive prpoblem
Well, either the hard drive inside has come loose from it connector, in which case opening the access door on the back and re-seating the connector will solve your problem, OR, the impact from the dropping has resulting in hard drive crash in which case you need a new hard drive.
Jan 20, 2012 | Toshiba Computers & Internet
Screen wont turn on no cracks or visable damage an was not dropped or abused
This is a common issue. The problem is a faulty graphic chip. You will need to take it to a shop or use the DIY guide from www.msbin.com to reflow the graphic chip.
May 22, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
My aspire netbook wont turn on, even though its plugged in and the power is on, it wont boot up
You might have a hardware damage if you have accidentally dropped the laptop. most probably the switch got dislocated try giving it to a service centre to tune it up.
Apr 20, 2010 | Acer Aspire One PC Notebook
Dropped my Olympus Stylus 1050 SW... now it wont turn on!
make sure the battery is charged and if it is and u r still having this problem try pluging it in a pc to see if your camera still works if it is maybe the lenz is messed up and if thats the case i cant help u with that
Sep 21, 2009 | Olympus Stylus / mju 1050 SW Digital...
Phone wont turn on
that happened to me once but i either drop it again to fix it or charge it becuz sometimes when i drop it, it shorts out the battery
Jul 27, 2009 | T-Mobile Dash Smartphone
My fujitsu siemen lifebook c-1020 wont turn on?
if its not your battery being dead it could be your hdd but lets hope not. some laptops cant take any impacts or drops at all. kills the hard drives
Dec 31, 2007 | Fujitsu Siemens LifeBook S7010 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
