Question about Motorola Mobility V265
Phone works but front cover display and flip screen blank
Both the front display bar and the flip screen light up but they are blank. Phone did not get wet and still dials and receives calls.
Samsung Anycall screen won't light up
hi i have a problem on samsung shw m110s ..i cannot see any display but its working ..what shoul i do?
pls help
Jul 10, 2012 | Cell Phones
My problem is my inside screen went blank white. About a week ago the inside screen started to do weird stuff like one day it had multi colored snow. The next it went blank. The next it looked like liquid...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Oct 05, 2010 | Motorola Mobility E815
Take care.
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
My blackberry pearl flip 8220 cellular phone not working
hello,it is a flex problem that mainly occurs to flip phones as a result of various opening and closing of the flip.all you need to get is a new flex to fix up the faulty one.you can kindly take it to an authorized expert to fix it up for you if you are not electronically inclined.and also it could be a affect the inner screen soonest if not attended to immediately.it could also be that the outer screen is bad so after the flex is replaced if the screen still does the same then you will need to fix up the screen.
please kindly rate this solution if it's helpful,
take care.
Jun 16, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blank screen
your phone has a problem with the flex cable go to a cellphone service and they will replace the flex cable and it should work just fine no need to buy a new one if u dont want to
Apr 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Screen on Razr
You will need a hot air soldering/desoldering gun for the work. Not possible. Only a trained technician can do it.
Oct 27, 2007 | Motorola Mobility RAZR V3
Cant turn my phone on
sounds like you need a new flip
Sep 29, 2006 | Nextel i850
Motorola Mobility V265 Logo
186 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
