I have a Philips Easylife LX3000 computer and wish to upgrade the RAM from 2Gb to 4Gb. Please would you send me a diagram or describe which panel I need to remove to reveal the RAM ports. Also would you tell me want RAM Memory I need to purchase and in what configuration. Thanks Dave Gwilliam dave.gwilliam@virgin.net
    Novelist:
    Scholar:
  • 160 Answers
Go to http://www.kingston.com and look up your model there, and find out what memory is available. Not all computers can take 4 GB of memory.
To access the RAM, you need to power down the machine, and open the case. RAM sits in DIMM slots on the motherboard.
To remove RAM, there are small latches on each side of the slot, open them carefully so they don't break. Lift the memory stick out gently.
If you break the latches (happens to all of us!) just make sure the memory is seated firmly in the slot. The computer will still run.
To insert RAM, notice that there is a small notch along the bottom of the stick, it needs to line up with the corresponding bump in the slot. Push the stick in gently but firmly until it locks in place.
Go slow, have plenty of light available, and you should be able to make this upgrade yourself.
If I've solved your issue, please mark this problem as "Fixya", if not please let me know what else I can do for you with a comment.
Good Luck,
Airoff
Posted on Jul 21, 2008
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
Can an old HP Workstation xw8000 Computer that is currently using 512 RAM (PC2100 registered 184 PIN ECC DDR SDRAM DIMMs) be upgrade using 4GB Kit (2 X 2GB) PC2100 Registered 266MHz 184 pin DDR SDRA
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
Mar 11, 2014 | Dell W4201C 42 in. Plasma HDTV
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
To upgrade power ram 2gb to my compaq presario f700 laptop,please help.thank.
Hi there. According to the specifications website on HP.com, this system originally shipped with 2GB of RAM, and only supports a maximum of 2GB. There may be a chance that the mainboard can support 3 or even 4GB of RAM, but it has not been tested thoroughly, and it is not guaranteed to work if you do go above and beyond the maximum supported specifications.
Jun 12, 2009 | Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Ram capacity on HP Pavillion dv2120us
nope....that 2 gig is true..and the reason it may be invisible is that it is not seated properly, or, it is mismatched..
Oct 16, 2008 | HP Pavilion dv2120us Notebook
EXTENDING EXIST 2Gb RAM to 4Gb
hai ,frist u go to
start--my computer(right click it)---manage---disk management---
see your new hard disk & right click and shirnk volume
Jul 13, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Can i upgrade my MT3705 to 4GB RAM?
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Jun 12, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
