Question about Jenn-Air Kitchen Ranges
Burner adjustment Ceramic burner does not respond to switch adjustments. Turn on front burner on high but no response to temp control. Turn on back burner and temp control ok but front burner on high with no sdj as to temp control
After discussing the problem with your advisor it was determined to be a faulty infinite burner control switch. I purchached a replacement and the stove works fine.This service was very halpful to me.
Posted on Jul 22, 2008
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
Burner temperature not adjustable. One of the burners either is high or in between control. Kenmore 790.4658/790.4659
Bad switch most likely but i'm not saying it will be easy to replace. It could also be something on the temp control circuit on the board?
Sep 13, 2013 | Kenmore Kitchen Ranges
Kenmore 79096011407 ceramic cook top. When front left burner is turned on, it goes to high and does not turn off. Had to use main breaker panel to turn off electric to the range. Can not find parts list...
Sounds like the switch for that burner needs to be replaced. Its possible that something else may be shorting out but usually its just the switch. Your ranges burners and switches are standard switches and burners for this type of range so the switch should fix it. Hope that helps.
Aug 29, 2011 | Kitchen Ranges
The back burner doesnt consistently light up.
If the flame doesn't go completely around the burner, ther is an obstruction at the outlet holes. Make sure all outlet are clear of dirt, rust,or any material. Even water will block the outlets.
Apr 25, 2010 | Weber Genesis Silver B Grill
Stove top electric burner
Switch for that burner most likely the problem
Aug 23, 2017 | GE JCP67FWW Electric Kitchen Range
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Mar 02, 2008 | Jenn-Air JES9800AAS Electric Kitchen Range
Front burner on grill won't adjust from high
Here is a couple of things to do.
Make sure your tank is filled.
Straighten Fuel hose, so it is not bent or kinked.
Does your front burner light with a match? If it does light then check the Crossover Ignition System.
Also, It could be the way the unit is turn off.
Try following thses steps, this will help to reset the excess flow safety device.
Turn all burner control knobs and the cylinder valve OFF.
Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve on slowly. Then go ahead an light your grill.
Nov 15, 2007 | Weber Genesis Silver C Grill
Kitchen Ranges Logo
251 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
