Question about Hotpoint HSS25GFP Side by Side Refrigerator
Ice maker for Model HSS25GFPJWW
The ice maker dispenses 1 cube then hums for both cubed and chopped. With no ice in the tray it does the same thing. The spiral screw is free and easily turned. I feel it's the motor at the rear of the unit.
  • Belangerfp Jul 21, 2008
    I have removed the Auger assembly and turned off the dispenser. I will let the assembly sit for a day or two to remove any frozen condensation. I will reinstall and test it then to see if your theory is correct. I may still need an Auger motor, if this doesn't work.
  • Anonymous Aug 13, 2008
    I had the same problem - Motor hummed but did not turn. I removed it and let it sit on the counter for 20 minutes, and then re-installed.
    It works fine, now.
    Scholar:
  • 50 Answers
Probably, but sometimes frost builds up in them and makes them unable to turn. They are gear reduction motors so you may not be able to turn it by hand, but if you take the ice container out, hold the door open, the door switch closed and press the ice dispenser and try to turn it whichever direction it's trying to go, you may be able to free it up. If that doesn't work you'll most likely need a new auger motor.
Posted on Jul 21, 2008
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
Oct 12, 2017 | Bosch Refrigerators
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Frigidaire model PLHS237ZDBA Ice maker dispenser won't switch back to cube ice it keeps crushing ice though its on Cube ice?
The rod under the ice tray was not in the correct position when the tray was inserted back into the freezer after removal. I get cubes now.
Feb 08, 2010 | Frigidaire PLHS237ZD Stainless Steel Side...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
NOT MAKEING ICE CUBES
well 9 1/2 times out of ten it is the ice maker i recommend you shop for a new ice maker... whirlpoolpartssurplus.com can get you a real good discount and free shipping...call them
Apr 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube maker only dispences crushed ice no cubes
remove ice bin look at small square opening reach in with your finger and pull down on vertical rod if it doesn't come down you'll have to remove complete auger asm from freezer (remove 2 1/4 screws and unplug electrical connection lift asm up and pull forward ) set out at lest 24 hours for asm to defrost and dry out then reinstall auger asm
Dec 19, 2008 | Frigidaire FRS3R5EMB Side by Side...
Icemaker won't dispense whole cubes, only chopped ice
Hello chitwnchk1
Welcome to Fixya,
You said,It chops ice when dispensing but won't just dispense whole cubes.
Any suggestions on how to fix it?
1. If the cubes dispense, but not whole cubes, there is not a enough water pressure.
2. r there is a restriction in the water line to the ice maker.
3. OR the fridge may not be level.
4. Is there a water filter and has it been Changed in the past 6 months?
Here are 4 reasons mentioned in the repair manual.
Shutoff arm in the off position
Ensure the shutoff arm is down and not in the raised position. If in the raised the position, the ice maker is in the off position and will not cycle.
Faulty Harvest Thermostat
There is a thermostat inside the ice maker that will close when the ice maker mold reaches the proper temperature. If the thermostat is not closing, the ice maker will not cycle.
Freezer To Warm
The ice maker will not cycle if the temperature in the freezer in not below 12 degrees. Ensure proper temperature in freezer.
No water getting to ice maker
The water inlet valve is the control device that allows water to enter the ice maker. It is energized during the last 5-8 seconds of the harvest cycle. During this 5 to 8 second period, there should be 110v across the two wires connected to the valve . If there is power supplied to the valve and the valve does not open to allow water to flow, the valve is defective.
However, if power is being supplied to the valve and water is flowing through it freely, it could be that you water supply line or inlet tube have frozen solid. These can be thawed with warm water or a hair dryer.
Let me know how it goes and what you found!
Thank You , Huuuum
Please remember to leave a rating!
Oct 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Problems with ice maker
Bsbbj,
If the cubes are fusing together (such as when you overfill an ice tray), your solution could be as simple as adjusting the fill volume (there should be an adjustment under the front plastic cover, and the cover should just pop off and snap back on unless you see screws attaching it) and when your ice maker was replaced this probably wasn't calibrated correctly. Your mention of the side of the maker bulging also leads me to believe the water is overflowing and freezing within the dispenser (causing it to bulge and not dispense).
I hope this helps and Good luck.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
213 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
