Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator TBX25zpk coils Freezing
My GE refrigerator coils in the freezer freeze up and build up so much ice that the freezer does not get cold enough. This happened about a week ago before I left for scout camp. I removed the rear freezer panel and defrosted the coils manually and it seemed to work but when I returned home they were froze over again. I have the panel off & the heater coil out of the fridge. I have 120 volts to the same wire that feeds the defrost thermostat. How can I tell it the problem is the heater, the defrost thermostat, the defrost control, or the temperature control? I am adept with the use of a VOM. Help!
  •  Spirit J Tomczyk
    Spirit J Tomczyk Aug 10, 2008
    Well we changed the thermostat, Defrost timer, Defrost therocoupler. Checked the heater element id was .05 out of spec. Finally got fed up & called out a repairman, low on freon. The frige uses R12 but since you can not get it the repair man used a universal type of freon (not sure what it was), can I use r134a if I need to recharge it again? Let me thank you for your help.
  •  Spirit J Tomczyk
    Spirit J Tomczyk Aug 15, 2008
    awiilyd
    Let me thank you for all of you help with this problem. It is just wonderful to be able to communicate with someone that has knowledge on such matters. Thanks again
    Scholar:
  • 50 Answers
It's almost always the defrost heater. If you have volts to the defrost thermostat the defrost control is working. Set your meter to check ohms and remove the wiring from the heater. If anything changes when you touch the meter leads to the heater terminals then the heater is probably good, but my guess is nothing will change, which means you've got a bad heater.
Posted on Jul 21, 2008
  • Austin DeBock Aug 10, 2008
    You shouldn't have to recharge it. It's illegal to add refrigerant without fixing the leak. If it was repaired correctly, it is hermetically sealed. NO you can't mix refrigerants. I can't tell you what he used, but you can retrofit most R-12 systems to accept R-134A if you change the oil in the compressor. I haven't heard of a refrigerant that mixes with any other refrigerant. That doesn't mean it's not available, I just haven't heard of it.
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
Oct 23, 2017 | Refrigerators
GE DL213908 Side by Side Refrigerator not freezing or cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Refrigerators
GE refrigerator / Freezer - Erratic freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 22, 2012 | GE Refrigerators
I have a ge gsl22wgph and the refrigerator side is not is not getting cold enough and the freezer side is not freezing. What is the problem?
First look at back wall of freezer toward the bottom and see if you have frost build up on the wall. If you do the problem is most likely the defrost heater and you will need to remove back wall of freezer, melt the ice from the coils and then change the heater at the bottom of the evap. coils.
Apr 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator side is freezing food and won,t hold at 37 degrees?
check the damper door that lets cold air from freezer to refrigerator and make sure theres no ice build up that can prohibit damper door from opening and closing its probably stuck open from ice build up
Dec 22, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side X side TFX20JA refrigerator not freezing or maintaining cold
Thank you for your help!! I was able to repair my refrigerater thanks to someone who had previously had the sam problem and was given three things to check. The problem was the heater in the freezer was burn out.
Jan 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
351 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
