Question about Magic Chef Microwave Ovens
Microwave has power but dead. Two year old unit.
  • Magic Chef Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please write back with your model number if you need further help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
My Panasonic Dimension 4 microwave/convection oven (NE9870) is dead. It was running, produced a small popping sound and is now completely dark. I've tried alternate electrical outlets and there...
Ken,
Usually there is an internal fuse and that is probably your problem. You will need to take off the outside cover of your microwave and then look where the power cord goes into the back of the unit. Look for the black wire coming out of the power cord and follow it. It should take you to the fuse. Hope this helps!
Dec 16, 2014 | Panasonic NN-T888S Convection/Microwave...
Samsung smh1816s
If side to side movement restored power, even briefly, the power line connection at the rear could be worn or defective.
Jan 10, 2014 | Microwave Ovens
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
My Kenmore microwave model 401.80083700 (about 2 years old) is completely dead. The outlet is good, circuit breaker reset, but I have no power to the unit. Any ideas?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | Microwave Ovens
Our microwave went dead. It's only three years old. My husband put some chicken wings in, closed the door, and everything went black. We plugged in a nightlight in the power source and it worked. Any ideas...
a few possible causes,
1, the high voltage fuse,
2, the high voltage capacitor
3, the slow blow fuse ( normally found on a small pcb inside unit)
other than that, check the door switches and maybe the x former.
good luck.
Jul 04, 2009 | Whirlpool GH4155XP Microwave Oven
It just went dead. from working great(7 years old
Blown fuse. Remove the outside cover and should be located near the area where the power cord enters the unit.
Jun 03, 2009 | Amana Radarange Microwave Oven
Kenmore Microwave 63301 - Power, but front panel doesn't operate
You have a failed membrane keypad or the problem may be on the board itself.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in most cases in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave cooked dinner and now does work
I had the same exact problem -- turned out the cooling fan for the magnetotron wasn't coming on because of a bad relay on the main control board. When the magnetotron overheated a safety kicked on which tripped an internal relay and killed power to the unit. GE repair guy diagnosed and resolved the problem. Only snag was that they didn't have a spare board so I had to wait a few days for them to deliver a replacement and for the guy to come back and install it. Now has been working for 5 days... of course I probably jinxed myself now! :)
Dec 18, 2007 | GE Advantium SCA2001BSS Microwave Oven
My microwave died
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 20, 2007 | Panasonic NN-S251 Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
