Question about Sony Playstation 3 (PS3) Console
PS3 INTERNET HOW WOULD I GO ABOUT SETTING UP ONLINE CONNECTION. DO I NEED A ROUTER OR WI FI OR ANYTHING. I DONT UNDERSTAND. I HAVE DSL INTERNET. I AM NEW TO ALL THIS SO ANY INFO WOULD BE GREAT PS3 INTERNET CONNECTION WIRELESS
  • 97 Answers
U need a wireless router
Posted on Jul 22, 2008
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I dont know how to connect my internet to my wii
the wii has a built in wi-fi reciever so you HAVE to have wi-fi if you dont buy a wireless router hook it up to your computer you need to have high speed internet for this then once your wi-fi is set up go to wii options internet connection then click search for connection if you have it set up right it will show your connection name then you click on it and it will retrieve the signal from your connection and you can go online from your wii.
Dec 23, 2009 | Nintendo Wii Console
Can you hook the ps3 up to the internet wirelessly
Yes you can connect wirelessly to the internet with your ps3.
Minimum Requirements
  • PlayStation®3 computer entertainment system
    Note: PlayStation 3 40GB / 60GB / 80GB / 160GB models ONLY (20GB model does not have built-in Wi-Fi connectivity)
  • SIXAXIS™ wireless controller (and USB cable)
  • AC power cord
  • A high-speed Internet account (cable or DSL) with an Internet Service Provider (ISP)
  • Router
    • Wireless router compatible with 802.11b or 802.11g Wi-Fi standards
    • Or an Ethernet (wired) router with a Wireless Access Point (WAP)
      You may need to open firewall port numberson your router to connect to the Internet.
      The PlayStation 3 will not connect to the Internet through the USB ports.
  • Updated system software installed on your PlayStation 3
    Visit PlayStation 3 System Software Update to download and install the most recent version.
  • Your Wireless Network Settings
    • SSID
      You will need to know the Service Set Identifier (SSID) of your wireless network. Also make sure the WAP or wireless router is set to broadcast the SSID; otherwise, the SSID will NOT appear on the PlayStation 3 scan results.
      If you do not know this information, speak to the person who configured your home network (i.e., wireless router) settings.
    • WEP or WPA Security Key
      If your wireless network access is security-enabled (encrypted) from open access, you will need to know your WEP (Wired Equivalent Privacy) and WPA (Wi-Fi Protected Access) security key or password
      If you do not know this information, speak to the person who configured your home network settings.
    • MAC address
      You may need to enter the Media Access Control address (MAC address) of your PlayStation 3 into your WAP if it is required by your network settings.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
PS3 INTERNET
wi-fi comes built in 2 the ps3, but i dont have one so im not sure how to set the connection up
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
WANT ONLINE FOR PS3
Try creating an Account from the Account management section on the PS3's Internet Explorer. Then when it asks for your Information that is WLAN or Internet Wi-Fi. Just select search, and select the one that has the highest %. Hope this helped.
Sony Playstation 3 (PS3) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
