Question about Acer AL1916W 19" LCD Monitor
Acer Al 1916 W mind of it'e own
Screen powers up, bakground appears for 1+/- sec. then goes black. let it cool down, unplugged and pluged, powered down...any thoughts Worked fine until now.
  • deyanpb Jul 24, 2008
    I turn my monitor on it stay for few seconds and then the screen goest black. If I turn it off and on again, it stays again for few seconds and then it goes black again... please help me
  • Sydbnk Jul 28, 2008
    Hm yeah same problem here..
    i can boot my pc and at the start it works fine.. then suddenly i see the lower left corner going black and the screen starts flickering. and eventually the whole thing just goes black. but the power on switch is still Green tho.
    then if i turn the monitor on and off again it works, for about 5-7 min then it does the same thing again.
    ive tried moving the monitor around to different locations on my desktop.
    and messing abit with the VGA. didnt seem to work tho.
You need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Posted on Jul 30, 2008
Acer aspire 5336 black screen...when i turn on the paltop the acer logo comes on and it boots up , while it is booting up the screen goes black, i can barley see the icons on screen underneath..if i...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 26, 2012 | Acer Aspire One PC Notebook
Acer 1916
Go into control panel, power options, go to hibernate, "top right" and click. Uncheck hibernate box, next! power schemes, " top left " and click, go down lelt side, "system standby " select never from the list and close window. This will prevent your laptop going to sleep, shutdown windows when you are finished.
Apr 23, 2012 | Acer Computers & Internet
ACER screen goes black after a few minutes of being on. I then close the laptop then log on again and the screen comes on then flickers off back to black, can very faintly see the desktop in the back...
Hi. This might be an LCD issue or connector inside th LCD from the motherboard is loose. You may try troubleshooting the issue first before you send the computer for repair. This process will drain the remain electrostatic energy to your motherboard which sometime causing the issue. Please follow troubleshooting steps below.
Take out the battery and unplugged the power adapter
Press and hold the pwoer buttong for 30 secs
Put everything back in
Power ON the computer
have a good one!
Jul 29, 2010 | Aspire Acer 7520-5071 Notebook
Viewsonic n2750w turns off half a sec after power on, still sound
THE 1000 UF CAP IN THE POWERSUPPLY IS BAD MOST OF THE VIEWSONICS HAVE THE SAME PROBLEM EATHER THE 1000 UF CAP GOES BAD
OR THE 470 UF CAP GOES BAD DEPENDING WHICH ONES YOU HAVE
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
I have an SVA LCD Model VR-17S Monitor that has a black screen
Sounds like the Backlight balance sensor circuit is shutting down the inverter supply. A weak bulb can cause this or a malfunctioning sensor circuit can cause it too. Best method to troubleshoot is to substitute good bulbs; if it still shuts down, look for a pair of small electrolytic caps on the inverter board near the bulb sockets. They may be weak.
Monitor Mike.
Jan 03, 2009 | Computers & Internet
Shut it off this a.m and now it won't come on. screen black. can hear it run a little
press and hold the power button for 5 sec. that will shunt down the machine. unplug the machine, press and hold the power button for additonal 30 sec. plug in the power cord and restart the machine
Dec 05, 2008 | Acer Computers & Internet
AL 1916 s
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
My moniters screwed
Sometimes this is due to graphics cards, but most of the time it is due to drivers. If it does not happen when you are using your PC for other things the problem probably just lies with the graphic card, driver, and this particular game or any game similar. Drivers are the most notorious! Check your requirements on the game for graphics cards recommendations! Let me know!
Oct 10, 2007 | Acer AL1916W 19" LCD Monitor
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
216 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
