Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Battary fail my labtop is on through adaptor only inside windows when the cursor on the battary icon it gives plugged in,not charging
  • Anonymous Nov 08, 2008
    no sound too and battery is not charging .i need a sound driver where do i find it ?
  • riteshranjan Mar 26, 2009
    notebook is on with adaptor only.. battery is in the notebook but tray icon says on ac power and when ac goes off, notebook gets off instantly...i.e., battery not working.
    when notebook is on and i remove and reinsert the battery.. it says charging and charging light blinks 5 times and goes off and again tray icon displays the on AC power status
I need sound , vga and modem for my labtop "mercuryD1400T"
E-MAILayman_mon111@yahoo.com"
Posted on Jul 21, 2008
Have tried to reset. Did not work. Have tried several outlets. Did not work. How do I chcek the battery.
It would help knowing what operating system is I.e. Windows 7 or 8.can you get into safe mode by repeatedly tapping f8 this should give you drop down menu for last known good configuration.choose this to see if the laptop returns you to a desktop.the battery can be checked by leaving the power supply in until you get to the open screen desktop then remove power supply and check the icon for battery bottom right.if you hover the cursor over the icon it will give battery life in percentage.batteries eventually fail mainly because people do not charge them properly.you need to run it flat occasionally and do a full recharge.once it reaches 100% take the power supply off and run it down to 20% and charge back to 80 % half a dozen times in between full charges?also in control panel there is an icon for battery whereby you can force the battery to discharge so you can re educate the full charge memory,this usually increases the stamina of a failing battery.
Apr 12, 2015 | Computers & Internet
When I switch on the laptop it will not run on mains power ,only battery power, however when i shut down the laptop the battery is being charged correctly,
The power options have been changed,when it's on hover over the battary icon down next to the clock,it should say plugged in & charging if not right click on the icon & select power options & then select an option from the menu on the right,go through them all & change them to suit you or create a power plan of your own.
if this doesn't work then it's because the enpowering tech is controling the system so press the green "e" symbol at the top of your keyboard or on your desktop & select the battary icon the settings will be in their or in the settings tab,just have a look around you'll find it.
Sep 28, 2010 | Acer Aspire 5610-4648 Notebook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Acer aspire 4930g,charging, at first 1% to 95% the
yes you labtop battary driver may be currepted. so install fresh battary driver
Apr 29, 2009 | Acer Aspire 4930-6862 Laptop
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
New battery charges but won't work
YOU HAVE A FUALT CONNECTION TO THE BATTARY AND NOTEBOOK POWER SUPPLY AND MAY BE A WIRE COME LOOSE INSIDE THE LABTOP
ROD
Feb 04, 2009 | Toshiba Satellite A105 Notebook
Labtop does not turn on
Try this; Disconnect from the AC outlet rmove the dc plug from the jack. Remove the Battery and wait for 5 mins and plug in the AC-DC adaptor without the battery. If the Laptop runs, then wait for the Windows to totally boot up and while running try to put back the battery and observe if it still charges. If it won't still boot up repaet the procedure and before connecting the power remove the memory modules first and install 1 memory at a time.
Hope this helps.
May 02, 2008 | Acer Aspire 5630 Notebook
Hi my name is Ahmed
motherboard is damaged you will need a new one to get this unit up and running
Apr 29, 2008 | IBM ThinkPad R50e Notebook
Thinkpad does not respond - bizzare!
Hi, Based on your post/description that it was not the laptop that was dropped and that all the connections are snugly fitted to where they should be, the dropping of the moused caused the laptop to be dead, then it is likely that the +5VDC of the mouse cable has shorted to the ground wire. The short is reflected towards inside the motherboard of your laptop. This +5VDC is common to all the USB ports, PS2 ports, and many other parts of the laptop. The short would open up a fuse somewhere inside. I can only surmise that the power supply is involved. You may need to check that the powersupply/AC adaptor (if present) is giving juice to your laptop with the use of a VOM, since as I understand it, simply plugging in your laptop to the mains would lit an indicator that ACpower is available. Normally a surface mounted fuse is on the motherboard right after the jack where the AC adaptor plug comes in and right before a reverse protection diode. If you are uncomfortable opening your unit and would not be in a position to do component level repair, you are probably better off seeking the services of a qualified service professional. Hope this give you and idea. Good luck and kind regards.
Aug 20, 2007 | IBM ThinkPad X41 Tablet PC
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
66 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
