SOURCE: beater bar does not work dyson DC07
If the beater bar does not spin freely, and the belt still seems to be in place, then you may not need a new clutch, but you may need to reset the clutch. This is done very simply by keeping the beater bar section of the vacuum flat on the floor and reclining the handle all the way to the floor so the entire vacuum lays flat. There is a mechanism in the vacuum which resets the clutch. You will probably not hear anything when the clutch resets. I sat on the phone for an hour and a half to hear this simple technique is built into the vacuum, but excluded from all instructions and website customer service information.
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
SOURCE: Dyson DC07 main power switch
I just had the same problem and took apart the canister part, cleaned it real good (a ton of dust came out of it, i shook it out and vacuumed it with another vacuum and put it back together and it works fine. I think it may be a like a kill switch so that the motor doesn't burn out on you. If you use tape or something to keep the button down I think the motor will overheat and burn out eventually. With all vacuums, I've learned they have to be cleaned pretty reguarly. I vacuum every day and there is no end to the amount of dust it picks up, no matter how much I clean.
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
