Question about Kenmore 64742 Electric Dryer
Kenmore Dryer 70 series
I have a 70 series Kenmore Dryer, recently replaced the timer and the heater element. Occassionally the dryer won't heat, but most of the time it will. Also, the more major problem I'm seeking an answer to, is the fact that the timer still doesn't turn off the dryer....it would continue running for hours if left untouched. This doesn't work whether in timed mode or a preset mode.
  • 903 Answers
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Posted on Sep 14, 2010
My kenmore 70 series dryer is working but no heat
The heating element in the dryer is got short and causing this problem. If the heating element checks out ok then its faulty timer motor causing the problem.this 2 parts are to be checked.First the heating element and next the timer control board motor. Locate the heating coil for the dryer along the back of the appliance behind the drum. The coil resembles a large, stretched spring.Check the back of the dryer to see if the heater coil is warming up while the dryer operates. Keep hands clear of the dryer at all times while inspecting the coil. If it does not begin to show obvious signs of warmth within one minute, the coil is likely burned out and must be replaced.You can also test it with meter.If there is no continuity the element is confirm faulty and needs replacement.--------- You can get required parts from www.repairclinic.com .--------- this should help.Thanks.Helpmech.
Jan 26, 2011 | Dryers
Electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Nov 05, 2010 | Kenmore Dryers
Kenmore 70 series
positon sensor or timer issue replace
Mar 09, 2010 | Kenmore 63942 Dryer
My kenmore series dryer does not heat. the timer
the heater element has two parts to the heat coil if one of the coils breaks it will not get hot enough to heat the load all the way to set of the sensor to stop . it seems like you need to replace your heat element . if you want to know how to take it apart i have a couple of posts that tell how or reply back the coil costs about 89 dollars you can get one pre strung for around double the cost
Feb 25, 2010 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
My kenmore 70 series dryer isn't drying - changed the heating element, changed the thermal fuse, and the high limit thermostat. Lint is cleaned and the motor is running.
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
May 26, 2009 | Kenmore 62602 Electric Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore 64742 Electric Dryer Logo
235 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
