Question about Brother MFC-3240C All-In-One InkJet Printer
Mfc-3240c/lost maintenance guide
Lcd panel says can not print. Lcd panel says check routine maintenance chapter in users guide.
  • ing cor Sep 08, 2008
    I have disconnected from power and re-plugged in but to no avail, please can you help.
  • nellquan Jan 14, 2009
    yes lcd panel says can not print maintenance and routine chapter in users guide
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Had a paper jam, took the paper out, now it will not let me print It Says ''unable to print, see troubleshooting and routine maintenance chapter in users guide. I don't have the guide. Can you tell me what...
its possible your encoder strip came off of the printhead assembly.
you will need to check by taking off the scanner assembly, then the upper cover.
look at the encoder strip and see if its in the groove of the printhead.
May 07, 2009 | Brother MFC-3240C All-In-One InkJet...
Printing after being on same phone line as printer/fax
This link will open the Users Manual, but you will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open it.
Go to page 12-4 in Chapter 12, Troubleshooting and routine maintenance. Follow the actions recommended for the Unable to clean error message (and the four other Unable to... error messages).
Jul 04, 2008 | Brother MFC-3240C All-In-One InkJet...
Will not print
What 2 digit error code does the machine display, too?
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
I have the same error message “Check the Troubleshooting and Routine Maintenance Chapter in User's Guide" I called customer service for "BROTHER 1-800-284-4329 USA; 1-877-BROTHER for CANADA. The Tech’s and I performed a series of diagnostic test, via the phone but were unable to solve the problem... Brother seem to believe that I have a defected printer head, Brother referred me to a local authorize service agent for Brother. I do have my User's Guide and there is no additional information that I was able to use to resolve this problem. HOW EVER, I am able to get the machine to print by opening the cover and close it as if I had installed ink, or removed a paper jam “SIMPLY OPEN AND CLOSE THE COVER”. I also vacuumed and blew the insides and the outside buttons of the machine with forced air from my vacuum, after all that I still have the same problem. My solution...buy a new machine mine is 32 months old and I probably have ran 15k or more print, fax, and copy jobs.
Some times we need to know when to move on, TIME IS MONEY AND TIME WASTED IS UN-REFUNDABLE.
GOOD LUCK
TG/Ks
Jan 22, 2008 | Brother MFC-3240C All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
203 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
