Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water Coming out the bottom of the washer
My whirlpool washer, ultimate care 2 filled up with water and started it's cycle but is pouring water out of the bottom - rather than out the hose and into my laundry sink. Where on the bottom would it be coming out?
    Sniper:
  • 68 Answers
This sounds like you have a bad pump. To replace the pump:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the pump.
Please rate this solution
Posted on Jul 29, 2008
    Genius:
  • 1,028 Answers
Lean washer back and ck pump for gray area on white pump back probably hole in pump
Posted on Jul 22, 2008
Water is coming out the bottom and not in to the loader
your fill hose is separated at the solenoid or you have a broken hose. Have someone look under the unit and see where the water is coming from. If there isn't a floor panel on the unit, pull it away from the wall and tilt it back so you can see the action underneath the unit. Start the cycle and see where the water is coming from. Stop the cycle and fix the leak.
Jan 08, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
My ultimate care 2 washer is leaking water. It appears to be coming from somewhere around the pump. It leaks whenever there is water in the tub. it does not have to be running at all. I poured a partial...
this could be one of 2 thingsyour not on a level surface or the seal has gone south./well i lied here is another therory your out let is not on or has a leak ,set it up a little higher on some bricks and run a short cycle see where its seems to be comeing from.
Oct 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
ULTIMATE CARE II WASHER - MODEL LSQB520JQ0 IS LEAKING
you can tip this unit back, the bottom is open and then oyull be able to see where the leak is coming from, any part wharehouse(online stores as well) will stock the pump if needed.. most common cause of leaking pump is fron center shaft youll see the water line
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
131 people viewed this question
Dan Webster
Dan Webster
Sal De
