Question about Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
Dryer runs for 3-4 minutes and then shuts down. Once it shuts down you can press the start button and you hear buzzing sound.
I have cleaned the lint from everywhere. I saw on one post it might be a timer. Wet clothes everywhere please help.
    Genius:
  • 1,028 Answers
If you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Posted on Jul 22, 2008
Push the start button and nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Roper RGX4634KQ Gas Dryer
Dryer runs but does not stop, also does heat up.
I have the same problem If you find out let me know someone told me it may be a timer switch. josephr313@aol.com
Aug 20, 2009 | Roper RGX4634KQ Gas Dryer
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Roper REX5634KQ0 runs for two minutes in any cycle and then stops
This problem sounds like a bad motor bearing causing the motor to overheat, when the motor overheats there is a thermal protector that opens and the motor will not run until it cools down.
Jan 06, 2009 | Roper REX4634KQ Electric Dryer
Heat stops after ten minutes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
uty
Jan 02, 2009 | Roper RGX4634KQ Gas Dryer
I still need instructions on how to remove the motor
hi. not unless the blower is jammed with something.the top comes of, the front comes off the drum comes off replace the motor. if you need my assistance lets chat. thanks
Oct 12, 2008 | Roper RGX4634KQ Gas Dryer
Gas dryer hums when I press the start button but won't start
hi thats a sign of a faulty motor . replace the motor thanks the appliance doc.
Roper Dryer
May have bad split coils .When the dryer is running for say 35-40 minutes ,are you feeling any heat if you open the door??If not ,most likely your split coils are bad.
May 21, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
148 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
