Question about GE WSXH208A Front Load Washer
Door seal on GE Adora Washing Machine
The seal on the door is torn and water is leaking during the wash cycle. Where can I order a replacement seal and how do I install it?
  • 7 more comments
  • ellsworthm Jul 23, 2008
    have front loading ge washer, seal is torn how to i replace it
  • chafa9702 Aug 28, 2008
    i havethis machine for almost a year (purchase) i installed it for less then three months now the rubber is torn ripped water going into the switch at the sycle moment. its causing shut off. its a hazard
    i can fix it if i can find the parts
  • Anonymous Sep 03, 2008
    the seal on the drum has partly come off
    cant get it on correctly
  • Anonymous Sep 08, 2008
    The seal on the door is torn and while washing it leaks. I would like to know how to replace this seal. Also, this is the second washer, same brand and model in less than a year.
  • Serge Massicotte Oct 28, 2008
    Our GE Adora Front Loader washer "boot" tore two weeks after the expiry of the warranty. The cost to replace the front door gasket locally is C$155.99 plus taxes of 12%. The gasket sells for roughly C$130.00 in the US including shipping charges.
    Comments do not address the cause of the problem. It appears that when tumbling, zippers and other large solid objects on clothes get caught between the door and the gasket and tear the rubber. I now zip up and turn coats, etc, inside out and reduced the size of the load. I have temporarily applied a high heat rubber patch to the gasket. However, the unit may heat the water to a temperature the patch may not tolerate for long and I'm positive the manufacturer would state this may cause a further hazard. After three weeks this seems to work fine - as a temporary fix. Will get back when I've changed the gasket.
  • Anonymous Nov 14, 2008
    Same problem. Washer is about two years old. What a disappointment.
  • Anonymous Nov 24, 2008
    Me too! Same problem. One of the kids left a pen in his/her pocket, pen broke and pierced rubber boot.
    Machine does work great however, saves lots of money in power and detergent.
    I found one on ebay for $81 incl shipping - brand new!
    Pretty easy to replace onesself. Compression clip on outside at 6 oclock postion, small phillips head tension assembly on inside of washer at about 3 oclock position. 30 minutes to take apart and put back together, $81 for parts in a few days - Sure beats $75 service call and $60-150 an hour plus ridiculous mark up on parts!
    Good Luck!
  • Anonymous Mar 30, 2009
    Same thing for me, This is my second washer GE Adora piece of ****! Anyhow I need a new seal because its leaking all on the electrical parts and making it short out, very scary. Can anyone help me with this,
  • robynw314 Apr 13, 2009
    We bought the new gasket on ebay, but are having some trouble replacing it. The old part is off, but do we need to take the door off to get the new one in?
After going through 2 different places that sent me the wrong part, I finally got the right boot seal today from Home Depot Appliances. I just gave them my model number and they overnighted the new boot seal to me, and for only $100. To call a GE repairman, it was going to cost $70 in the trip and $170 for the seal. Rip Off. We did it ourselves. Saved a lot of time and waiting.
Posted on Mar 31, 2009
We have the same problem. We found the seal on ebay. Reg. price is well over $100, we found it for $74. Do a google search of your machine model replacement parts. When you find the part you need do a google search for that part number. You may also want to do an ebay search for the part number.
Posted on Oct 04, 2008
Water Leak?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 08, 2013 | Washing Machines
Water leaks with larger louds on kenmore front load eco
Feb 01, 2013 | Kenmore Washing Machines
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
Beko washer is leaking water from underneath
This video will show you in detail how to replace the door seal gasket and fit the new one properly to a Beko washer that is leaking water from underneath washing machine How to Replace Beko washing Machine Door Seal
Jan 24, 2013 | Washing Machines
Leaking front loader
You will need to replace the bellow (door seal) on the unit. Here is the part to order.
Nov 20, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Washer is dripping water at the front when filling and washing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution.It is possible that water can leak if there is gaps on the front door gaskets and must be checked for damaged gaskets which can give poor sealing of the door. So in this case the leak will happen more during the cycle and not on the drain cycle end.
check this video to see how to replace the door gaskets.
http://www.espares.co.uk/advice/washing-machines/a/7/1397/how-to-replace-the-door-seal-on-a-washing-mac.html
Jul 30, 2011 | Kenmore Washing Machines
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Piece of rubber came out torn. water leaks out
door seal must have hole in it replace hole at bottomof seal
Jul 06, 2009 | Washing Machines
Front door leaking during washing cycle
There are only two ways that water can leak out this way. it can be either the door seal or the door lock mech has become misaligned, causing a slight gap that is letting the water escape through.
I recommend inspecting the door lock mech for its integrity. make sure it is aligned correctly to specs. replace this mechanism if found to be faulty or misaligned. i would also inspect the seal for tiny ruptures as well. the slightest rupture or hole can allow small amounts of water to excape.
Inspect these areas thouroughly.
May 31, 2009 | Frigidaire Washing Machines
GE WSXH208A Front Load Washer Logo
3,709 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
