Question about Yamaha RX-V2090 Receiver
How I connect DVD Player thru Yamaha RX V2090
Sir,
I am trying to connect the DVD payer thru Yamaha V2090. There are separate S-Video "in" & "out" for vcr1 & 2, then there is a S-video connection for LD/TV and another one for "monitor out".
I have connected DVD S-video out -->to s-video in of V2090
and from V2090 LD/TV out -->to s0video in of the TV.
I am getting no picture.
If I connect the DVD directly, then I am getting picture.
It would be kind of you if you please let me know what I am doing wrong and How should I do the connection.
Regards,
Dipankar
  • idua Nov 20, 2008
    What would be the proper connections beween my Yamaha RX-V2090 and new technology of TV(HDMI), CD, DVD? I am completely lost and confused having tried various configuration.
    Thanks
  • 682 Answers
Please check your input source in tv and confirm right selection-check interconnect cables.
Posted on Jul 21, 2008
I have a new Yamaha AV receiver rx-v381,trying to connect an old CD DVD player, Sony dvp-nc665p. I have audio, no video. No HDMI on CD DVD player. What am I doing wrong? Help!
On my Yamaha AV receiver, DVD video (usually a yellow connector) passes through to a video output which then connects to the video input of the TV.
Feb 11, 2017 | Sony Audio Players & Recorders
Connecting a PS2
the rxv463 will not upconvert any video signals. its what they call a pass thru video switch. chances are you are using a red, white. yellow (composite) connection. you will then need to pass this yellow thru the receiver to the yellow output of the receiver and into the yellow input on the tv. the same rule would apply to the component inputs and outputs as well as the hdmis
Dec 07, 2009 | Yamaha RX-V463 Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
No DVD Picture
When you say "Traditional Cables", are you referring to the red, white, and yellow cables?
Once you connected those from Cd/DVD to the receiver, did you then connect another yellow cable from the "monitor out" on the receiver, to an input on your television?
This is generally the step that people forget about.
The back of your receiver should have a "monitor" or "tv" output on it. You need to connect another yellow cable from *it* to an input on your TV, then turn your TV to that specific input.
That should do the trick.
Mar 25, 2009 | Yamaha RX-V463 Receiver
How to connect dvd player to AV reciever
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
Jan 22, 2009 | Audio Players & Recorders
Is there any DTS decorder player that suit with Yamaha RX-V 2090? Thank you.
Try the Technics SH-AC500D Digital Surround Processor. Its outputs should match the inputs on the RX-V2090. I own both units, though I am using a DDP-1 with the Yamaha receiver. I use two separate amps with the Technics to achieve surround sound using my good vintage stereo system (two of them actually - one for front and ane for rear). The Technics is a nice piece of kit.
Aug 13, 2008 | Yamaha RX-V2090 Receiver
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
No Sound
Three things to look for for the no sound problem:
1) Make sure the pre-out main-in couplers have jumper wires in them
2) Make sure the mute is not engaged
3) make sure the speakers wires are inserted properly. you need to unthread the five-way binding posts before inserting the wire between the post nut and receiver.
Aug 31, 2007 | Yamaha RX-V2090 Receiver
RX-V2090 Bass Output Problem
A couple things to check on the no bass problem:
1) Make sure your center speaker is set for normal, not large.
2) Make sure your speakers wires are in phase (+ conn. to + and - conn. to -).
Jun 23, 2007 | Yamaha RX-V2090 Receiver
Yamaha RX-V2090 Receiver Logo
158 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
