Question about Northland D48 / G48 Side by Side Refrigerator
Northland 48" side by side is too warm
Both freezer and refrigerator are too warm (ice cream melting, etc). I turned it off after removing averything since one time a repairman had said that there may be ice in the wall in between and it would need to be defrosted. Today I do notice some water leaking from somewhere on the floor under it (not a lot though) and the front metal part of the wall in between the two sides is very hot with nothing on (no lights, nothing). A friend said to try to find an energy saver switch and turn it off, but I cannot find any. We have had really bad luck with repair people not to mention a whole lot of expense. Can you help or make any suggestions????
  • 330 Answers
If you have this unit for a long time, maybe you need Freon for the compressor. you can not do it yourself.
Posted on Jul 21, 2008
The freezer is keeping some stuff frozen, but ice cream melts right away. It seems that its cold, but not as cold as it should be?
Check and clean all around the outside, particularly underneath to ensure condenser clear. check fans running and compressor pumping.
Dec 17, 2015 | Jenn-Air 48" Side-By-Side Built-In...
Freezer is not even keeping ice cream from melting..and the 2 slots at the top in the back by the top shelf?? Are filled with IVE
Do an old fashioned dethaw of your icemaker. Remove food in compartment, unplug or turn off freezer. Leave doors closed, and get a thick towel and a pot of boiling water. Place the towel under the pot, close the door, and let the heat from the pot warm up that frozen freezer vent. That will clear the ice so the fan can draw cold air out into the freezer
Aug 01, 2014 | Samsung RS261MDPN - 26 cu. ft. Side by...
Freezer side is freezing and refrigerater is warm
You have an Iced up freezer the freezer "packed full of stuff?" If so you are blocking all of the vents that cool the fridge...The freezer section of a refrigerator is responsible for keeping the freezer frozen and the frige cool...air passes between the two compartments via the settings you set on those dials "a b c etc." Take everything out of the freezer and stick it all in coolers or something for a couple of hours see if there is ice built up around the vents at the sides and bottom of the freezer compartment. If so, the freezer needs to be "de-iced" normally this is accomplished automatically via heaters placed here and there throughout the fridge...So this may also be a source of your problem. if the heating element is bad, it would allow ice to form...I can also assume that the airflow from the fan in the freezer is "weak at best" meaning it is also full of ice... You can melt the ice with a hairdryer and some time of course...but be thorough with it. If you have a heat gun even better, just don't get it too close to the plastic or you will melt it. hope i've helped a bit...let me know what you find in there
Jun 09, 2012 | Jenn-Air 48" Side-By-Side Built-In...
Freezer is not freezing some items and not freezing some. Ice Cream is not freezirng, sausage & hotdogs are not freezing. Ham is not freezing, etc. There is no food blocking vents. I tried to...
Hi, The freezer is not staying cold cream takes colder temps...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Aug 02, 2011 | Whirlpool Refrigerators
Over a period of days the freezer gets warm then cold. Ice begins to melt then freezes together. Ice cream gets soft, then hard. I removed the panel in the back of the freezer. Unlike other defrost...
The refrigerator is sticking in defrost mode...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Nov 20, 2010 | Amana Side-By-Side Refrigerator 26 cu. ft...
First my refrigerator side stopped getting cold ,now my freezer isnt working the best , also theres frost in my freezer
you found frost in the freezer on the back wall . this caused no air flow through the coil. what has hapened is / the defrost system has failed . and the ref side gets to warm and next the ice cream will melt . look for bad heater or defrost terminator . and the defrost timer . . most compn problem .. mm
Jul 04, 2010 | Whirlpool ED2FHSS Side by Side...
The freezer has been melting ice-cream
The first thing to do is, give it a FULL DEFROST, the old fashioned way. set it for defrost or unplug it and melt all of the ice out of the air tunnels below and behind the freezer. In the refrigerator section, you will find a hole that you can stick your finger into, normally in the wall next to the freezer. This has the defrost timer in it. Give it a full turn CLOCKWISE to make sure the contacts aren't stuck. When you are sure all the ice is melted and the water has been dried up, power it back up. It will run properly if nothing actually went bad. The next step, if it doesn't work right, is to replace the thermostat.
May 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
My northland 48" side by side is not cooling on either reefer or freezer sides. Everything either defrosted/melted or got warm. The system is running and blowing only ambient air inside and the normal warm...
You could have something as simple as frozen evaporator due to defrost system malfuntion, bad compressor electricals or failed compressor. I believe the sealed system in that unit comes with a good warranty. I would contact Connie at the factory, 800-223-3900. She can help you find a servicer to repair it and also provide any further troubleshooting assistance you need. You can also find servicers in your area by visiting their web-site in the support area.
Feb 12, 2010 | Northland D48 / G48 Side by Side...
Northland D48 / G48 Side by Side Refrigerator Logo
406 people viewed this question
Top Northland Refrigerators Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Bill Boyd
Terry Weaver
Terry Weaver
Are you a Northland Refrigerator Expert? Answer questions, earn points and help others
