Question about LG Refrigerators
Have a 2005 model#LRSC26925TT LG fridge with front ice&water disp. and digital panel. Ordered replacement funnel and frame since mine is outdated and need to replace. Can we replace on our own and remove the digital panel without causing damage and if so how do we do this? PLEASE HELP!! CJK
  • cjkf48 Jul 21, 2008
    Thanks for your input. The front digital panel was never mentioned when I called LG for help. I was told the funnel and funnel frame had been updated and I would need to order both for replacement. I was given a name of a LG repair contact in our area, but I'm wondering if we can save some$ and do it ourselves-doesn't look hard if we had some guidance. Just don't want to scratch the front digital panel or break it off. Would appreciate any info on this. THANKS
  • 330 Answers
When you order the new replacement, did you ask the supplyer whether it can be replace the old panel? Sometime the wireing inside is different, I do not suggest you touch it unless you got the panel is completely same size and same founction and you know how? Otherwise it is a headache.
The panel must be right one.
Posted on Jul 21, 2008
  • Frank Chen Jul 21, 2008
    I din't see the unit and I couldn't give you any suggestions, but I know you can do it,if you check it carefully and open it step by step and write it down every steps and after you change it and put it back again, before you closed it, try it see if it is founction right. Good luck my friend, I am proud of you like to try everything.
Water is leaking from front part still making ice we checked water connection part no leaking from there.
Unplug the fridge first step, loosen the leveling screws in the front by turning them counterclock wise, slide out the fridge & remove the panel from the back ( 1/4" Hex Head screw extractor for an electric drill - small one - ) the panel on most is at the bottom. Be sure to save all screws for replacement !
Using a Vacuum sweeper, clean all of the dust & dirt from all the coils ( VERY CAREFULLY ) there is also a small fan with plastic blades that should be cleaned off with the vacuum first, then use Windex or similar cleaner & wipe them off ( VERY CAREFULLY ) these blades will break very easy. Now plug in the fridge ( be sure all cleaning tools & rags are out first before plugging in the fridge ) check to see if the fan is turning very fast. If all looks good be sure to check the small drip pan that catches the condensation or other water dripping from above. there may be a small funnel that catches the water & directs it to the small pan, it may be loose & slipped into the pan. FIX IT, with what ever you can. I used Tie-Raps on mine to secure the funnel to the copper pipe running through the small catch pan.
GOOD LUCK- Don't forget to replace the pan on the back of the fridge, don't overtighten the small screws, they will strip out easely.
Feb 01, 2018 | Refrigerators
How to replace LG LFX21976ST water valve
follow 1/4 inch water line where it enters fridge panel water solonoid valve is behind it
Dec 30, 2015 | LG LFX21976ST 3 Door French Door...
Trying to install dispenser funnel frame - had to detach wiring and plastic part, and in middle of doing this, but can't correctly orient the switch piece that screws onto frame and has the light &...
I have the same problem. Mine has stopped making ice now. Thinking about putting old piece back in and gluing funnel frame. Did you ever find a picture of the order fo the switch piece to frame?
Aug 16, 2011 | LG LRSC-26922 Side by Side Refrigerator
How do you replace the dispenser funnel on an LG Refridgerator model LRSC-26923
funnel itself squeeze in on sides to release tabs. so many tabs broke a redesign was made 5-30-2005 , have to replace frame bracket and funnell. models after tant had new design. part number from exploded view: 3016JA2002C funnel 278d location number exp. view
3210JA0006S frame 278b location '"" '' ""
Sep 10, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG refrigerator - Need help replacing a part in the door.
How to install part ac110-115v for lg refrigerator
Jul 10, 2009 | LG Refrigerators
LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Jul 08, 2009 | LG Refrigerators
Replacing funnel/funnel frame on LG fridge model # LRSC26944TT
I am a year too late to help this person but also recently had to replace Funnel Frame on my LG Fridge model # LRSC26925SW. Literally just finished so sharing a quick tip. Not sure if it's same on all models but worth an easy shot. Tried the screw driver thing with no luck as it was just digging into the plastic even at the one little tab hole at bottom of the Frame... So instead, I stood to left of Fridge and cupped my hands around the edge of the door and into the left side of the curved part of the bezel (more towards the bottom) and simply pulled towards me and out away from door (almost like clamping my grip tighter) and the bottom portion popped open with enough gap to work the rest off gently by hand. Pull out from the bottom first and then slide the assembly down to release the top. Once you replace the funnel frame and are ready to reassemble, work the top of the Bezel with the display in first and slide upwards, you'll know when it's in the right place and then snap the remaining three sides a little at a time with the side of your hand (firmly if necessary). It didn't break any clips in case you are wondering... they are designed to release and clamp in that fashion... Ice dispenser now works as good as new... Funny part is all I "really" needed was the Funnel, but LG changed the part and it would only fit if I also replaced the Funnel Frame. Good Luck to the next person reading this!
Mike W
May 28, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
Apr 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
205 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
