Question about Dryers
2004 kenmore 80 series dryer all electric
Wont blow hot air during drying cycle. could it be element or something eles? I am a journeyman lineman and former industrial electrician. I just need a little help with trouble shooting this.
    Genius:
  • 1,028 Answers
Ckd thermal fuse on element housing ..then element for continuity but also could be timer contacts or switch on motor but ck for burnt wires and 220 volts at back of dryer
Posted on Jul 22, 2008
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
I have a kenmore 70 series dryer that overheats in evrery cycle even in the air dry cycle. Another problem is that when the cycle is done the tumbler cuts off but the timer keeps running keeping the...
Sounds like you may have two problems but the main problem might be that the element may be broken and one side is grounded, The switch on the motor may also be stuck in the on position as well.
Feb 26, 2011 | Kenmore 62802 Electric Dryer
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Dryer don't blow hot air, everything else runs ok.
you need to check the heating element and the thermal fuse to see if they are blown.
Dec 19, 2008 | Kenmore 659 Electric Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Electric dryer
Most dryers have two fuses in them, one inline with the heater element and another thermal fuse in the main circuit. The one inline with the heater element can blow and the dryer will still run, but will not heat. If the dryer gets too hot it may blow the thermal fuse and kill power to the entire system.
Depending on your level of handiness, you may take the cover off (make sure the unit is unplugged from power) and look for a blown fuse. Most dryers have a schematic for repair somewhere on the unit, usually in the top control area.
KP
May 14, 2008 | Dryers
Dryers Logo
144 people viewed this question
Top Dryers Experts
