Question about Toshiba 57H81 57" Rear Projection Television
Toshibia Hyperboard Problem
Thanks for the info. Just wanted to get a head start on the repair of the wiggley lines on my projection screen. Would you happen to know part number of the capicators to be replaced. Trying to order from Digi-Key . there are so many different types of 10uF 16V volts electrolytic capacitors. Surface mount? UD WT Series or low impedace hight temp?Please help!
Thanks
Joe Obeid
jobeid@hdgh.org
    Scholar:
  • 87 Answers
Get 10uf/16v radial lead 105 deg caps. Cut the leads short so they fit under the shield and give them a bend like the letter L when you solder them on the pads. These caps are easier to use than the original surface mounts and much better. Be very careful removing the old caps as not to lift the pads to which they are soldered. I will caution you that this job requires expert soldering skills and a good soldering tool with a fine tip. This is not a job for a novice. I know plenty of pros that botched hyper modules. Take note to observe polarity of the cap when installing. I don't know the part numbers off hand but you can Google "Toshiba hyper module kit" and find a list. I use an ESR meter and test for the bad caps. You will use about 7 or 8 so it is cheaper to order a pack of ten.
Posted on Aug 03, 2008
My 57h82 picture has picture noise in form of small jagged/wavy lines at edge of objects - particularly noticable for text or numbers. This appears on all channels and with all input sources. How to fix?
Is a common problem. Your hyperboard has failed. You can get a repair kit from www.TvRepairKits.com or buy a used hyperboard - but it will also fail someday unless it has been repaired with better parts than what the factory supplied.
Dec 22, 2010 | Toshiba 57H82 57" Rear Projection...
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
When turned on, the screen has waves in it across the top and flickers. It is unreadable. When the TV warms up it seems to be better but is starting to flicker or flash all the time now.
Your Toshiba TV has hyperboard inside and there are few electrolytic capacitors (may be 10) that need to be replaced.
If you are comfortable with soldering parts in PCB then go ahead or ask help to any friend that knows electronics stuff repair.
Let me know further query.
Thanks.
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Dont know what a hyper board looks like
DO YOU OWN SOLDERING STATION, SOLDERWICK, SOLDER. TAKE IT TO A SERVICER YOUR IN OVER YOUR HEAD
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
Card reader replacement
I suspect that it won't play any source that uses progressive scanning. The likely problem is the hyperboard or scaler board. This component allows the TV to switch from sandard definition TV to HD. Typically, the hyperboard will cause shaking and wiggly images especialy noticeable at the top of the screen. It will generally work better the longer its on. Expect to spend $400-500 to resolve this.
michtech
Dec 09, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Thanks for the reply
look at this thread.A lot of info there. I have ordered the caps at digi-key.com, part # 493-2105-1-ND
http://espnhd.com/voice/showthread.php?s=372087d540bc5c4b9b4d68631c67b610&t=10984&page=2&pp=20
Jul 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Hyperboard repair Toshiba TSB
Best way is to check in circuit with ESR meter........
EDS-88 CapAnalyzer..... www.eds-inc.com .........................
Mar 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
