Question about Maytag 23 cu. ft. Side-by-Side Refrigerator MSD2356
Fridge not cooling properly
Especially in the summer months our fridge doesn't get really cold...It is at setting #9 right now and still doesn't seem very cold. Any help would be greatly appreciated!
Thanks,
Mike
  • 943 Answers
Hi mike the best thing you can do. is pull fridge away from wall an clean all coils. very important. it will make the fridge run better. thanks the appliance doc
Posted on Sep 30, 2008
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
My Fridge is running Hot on the freezer side and the temperature is rising. Ice cream is melting etc. Fridge side seems OK but also not really cold. Which of the the settings on the internal dials 1 to 9...
It sounds like the condenser is dirty. It's under the refrigerator.
This is easy to do. Just get all the dust out of the condenser and things should start cooling down.
I hope this helps. Please leave feedback.
Thank You.
Aug 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
Freezer is cold... fridge is not
Could you pull it away one more time and feel the compressor to see if cool, warm or too hot to hold your hand on. That tells me a lot of things. I want to see if your compressor is shutdown, running but not cooling or trying to start and cannot. That will help me to answer what we need to do next. Sea Breeze
Aug 19, 2009 | Refrigerators
Maytag MSD2356AEW Side by Side Fridge not Cooling enough
Deforster not kicking in. There is a chip that is supposoed to kick in thte Auto Deforst on the frezzer side. It fails and the system freezes up and can not circulate cold air form the freezer side to the Fridge side. Simple repair, but yo will needed a service tech for this.
Jul 20, 2008 | Refrigerators
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
112 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
