Can't take off the ADF off Canon printer
I am trying to figure out how to take off the ADF from the Canon D680.
Some how it got some paper stuck right in the middle and I can't take it
out and the ADF won't close
  • 1,326 Answers
To take the feeder off you have to take the back pannel off ( 5-6 screws) the ADF pillars are locked in with a clip on each side, one is easy to get out but the other one is behind one plate with one screw. Then you have to disconnect the ADF clip and the grounding wire. Now it's off..... Good Luck...
Posted on Jul 22, 2008
I have a message on screen sayng " ADF Jam" there is no paper jamming the system. I cannot make this message go away, and so i cnnot use any other function of the printer. How might I clear...
Hi travlynn2,
  1. The ADF
    unit is the grey paper tray located on the top of the scanner unit.
    Check the following points if it does not feed paper, or you receive an "ADF jam" error message:
  2. Check the position of the ADF document guide:
    1. Lift up the ADF unit. Locate the document guide on the underside, as shown here:
    2. The document guide should be tucked in behind the grey plastic casing, but a paper jam can push it out of position. Figure 8 below shows the correct (1) and incorrect (2) positions:
    3. If your document guide looks like example (2)
      on the right, lift it out on the right-hand side. Tuck it in behind the
      grey section, so that it matches the example on the left (1).
    1. Close the scanner unit.
    2. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    3. Test the printer by scanning or faxing via the ADF unit.
  3. Check the ADF edge guides:
    1. The adjustable paper tray edge guides must be set to the correct paper size for the paper you are loading. Otherwise, the paper may skew, misfeed and/or jam.
    2. Slide the edge guides to enclose the loaded
      paper (in the direction of the yellow arrows below), without causing it
      to bunch or crease. The paper should be aligned with the relevant paper size marker:
      Figure 9. The ADF edge guides.
  4. Check the ADF unit feed rollers:
    1. Open the cover of the ADF by pulling up the grey lip, as shown below:
    2. Check thoroughly for fragments of paper and foreign objects. Take care not to tear any jammed paper when you remove it.
    3. Use the green gear (circled in yellow below) to turn the paper feed rollers and feed through jammed paper:
    4. Paper dust or foreign material on the rollers may cause paper to misfeed. Clean these parts with a damp, well-wrung cloth:
      1. The upper paper pickup rollers (circled in red, above top left). You can turn these by hand.
      2. The lower paper pickup rollers. These will rotate as you turn the green gear (circled in yellow above). See the inset for a close-up of the lower rollers.
    5. When complete, close all the covers.
    6. If the printer is displaying "ADF Jam, press start to continue", press the B/W Start button to clear the error:
    7. Test the printer by scanning or faxing via the ADF unit.
  5. Check that the ADF unit sensors are not obstructed.
    1. Open the cover of the ADF unit.
    2. Look at Figure 12 below. Check the position of the black plastic parts (the actuators) circled in red.
    3. If the black plastic actuators do not stick out from the ADF cover, they may have been pushed out of position by a paper misfeed and be obscuring the ADF sensors. Tap the back of the ADF unit firmly to release the actuators.
    4. When complete, close all the covers. Check and test the printer as explained in Step 6.d.vi.
Hope this helps.
Thank you for using FixYa.
Sep 21, 2011 | Epson ACULASER CX11NF All-In-One Printer
I have canon 320 MX, and I recived all the time a messege - document in the ADF, I press OK , then I recive a second messege - close the feeder cover and eject the document.NO documents are in the printer...
Hi!
look more closely on the ADF section, if there is no paper remains then you must need to check if the paper feed sensor is not press down or stuck. This sensor, a small plastic latch slide is responsible for detecting load paper in the ADF section. Check if there is something that keeping it stuck in that position. You will need to open the cover of the ADF section to do this.
Hope it works.
Oct 02, 2010 | Canon PIXMA MX310 All-In-One Printer
When we try and fax more than one page it says, Check document open adf and there is nothing under the glass
you have an exit sensor sticking (usually black plastic that flips back and forth) it would be where the paper comes out on the feeder. Usually these type of sensor "clip" into a holder and can come dislodged and crooked causing them to bind, usually from pulling a jam out backwards.
Aug 04, 2009 | Canon imageCLASS D680 Laser Printer
My CANON PIXMA MP530 is showing the alarm, "Document in ADF."
Open the top cover of the ADF and look for a rectangular hole with a lever stuck down. That lever should only go down when a paper is placed in the feeder, and sometimes they get stuck in the down position. A bent paper clip might help you lift it gently...
Jun 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Had paper jam, Cleaned it out.
Ni there is something ( a small piece of paper) over the sensor in doc feeder- have a close look with a torch
Apr 23, 2009 | Canon imageCLASS D680 Laser Printer
Help
check weather any piece of paper stucked inside the adf. Next check the paper sensor in the adf , it may be stucked or broken . .
Apr 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon D680
need to replace pickup rollers, you might want to replace all of them.
Dec 20, 2007 | Canon imageCLASS D680 Laser Printer
Canon d680
try new cartridge. are you using new or remanufactured?
Nov 09, 2007 | Canon imageCLASS D680 Laser Printer
104 people viewed this question
jasbo
jasbo
