Question about Xerox Office Equipment & Supplies
My xerox 8830 dds printer is showing an error code LL-22 which is a high voltage transfer failure, how do i rectify the problem.
  • 2072 Answers
SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message Solution: Perform a RAM Clear bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a RAM Clear will restore all of the WorkCentre's settings to the factory defaults. It will also clear all faxes in memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print out your Phone Book before performing the RAM Clear, to assist you in reprogramming your Speed Dials and One-Touch Buttons. It is also recommended to print out your System Data List to assist you in reprogramming your system settings. If you are not sure how to print your Phone Book or System Data List, refer to Related Items at the bottom of this page.
To perform a RAM Clear:
  1. Press the [Menu] button on the Control Panel.
  2. Press the [#] key, then press 1934.
  3. NOTE: These buttons should be pressed quickly. If not successful, try varying the speed you are pressing the buttons.
  4. When this step is successful, the bottom right-hand corner of the LCD Display will read 'TECH'.
  5. NOTE: If you are unable to access Tech Mode, please refer to Related Items at the bottom of this page.
  6. Press the [Menu] button to start navigating the menu.
  7. Press the [Up] or [Down] arrow button until the LCD Display reads 'Memory Clear', then press [Select] button.
  8. The LCD Display will read 'US and Canada'.
  9. Press the [Start] button to clear memory.
Posted on Jan 19, 2008
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: xerox 7750 fan failure code
That is the fuser fan either running slow or stalled. It is located on the back, looking from the back on the upper left. You will see the slotted opening.
You have to remove the side covers and the top cover to access it, Sometimes taking off the silver sticker in the middle, removing the rubber cap and oiling it will help.
To buy one. Go onto google and search for " the parts drop". Call them and ask for Britt or Joe, they will know what fan and be fair on a price.
Taking your time it should take half an hour to an hour to replace. Not hard, just take your time and make sure you note how you disassemble. You will be fine.
Posted on Oct 31, 2008
leroyal
  • 2120 Answers
SOURCE: error in xerox 6250dp of fp transfer roller expired
You need a new transfer roller.
Posted on Jan 25, 2009
  • 114 Answers
SOURCE: showing hammer voltage 2 error
the problem comming from logic board. need to change the logic board and hammer bank cable at the same time.
Posted on Jan 30, 2009
LL56
This type of code has not recovery procedure which could mean replacement of hardware component. LL-56 refers to a power board fault on the printer and occurs during power on self test.
Refer page 1-10 for the code description in this service manual.
http://www.printertec.com.br/arquivos_download/xerox/xerox8825.pdf
Jul 31, 2014 | Xerox 8830 Copier
Xerox 8830 LL-60 Checksum fault
enter in diag mode and press 03-60 reset the nvm
Nov 01, 2010 | Xerox 8830 Copier
How do you reset an Error code LL-05 on a Xerox 8830
enter in diagonistic mode by pressing 0 then on then press10-30 then on andoff
Oct 19, 2010 | Xerox 8830 Copier
Tenho uma ploter 8830 ela deu um codigo LL 06 o que eu faço para tirar este codigo
Xerox tiene ofrendas de instrucción de cliente llaman 1-800-275-9376 x773. Ofrecen información española. Espere que esto ayude. perdón no está más.
Aug 12, 2010 | Xerox 8830 Copier
How do you fix Status Code LL-22
‘LL-22’: High Voltage Transfer failure. I would suggest calling your local Xerox tech.
Jun 24, 2010 | Xerox 8830 Copier
I'm setting up a 8830 and a 7356. The scanner says ready but when I put in the paper it says not ready take out the paper. The 8830 has a code LL-22, is that something I can fix?
As far as the scanner insert a sheet to copy and when it says NOT READY instead of rolling the paper out the way you put it in, roll it forward until it comes out the back.
An LL-22 is a HV power supply error. Most of the time when I see this the corotron wires are contaminated by developer. You need to clean it with a vacuum.
Nov 25, 2009 | Xerox 8830 Copier
Error code E701
Е-701 the malfunction on frequency temporary signal, which can arise out of for undue execution temporary parameter. The Sensors fix time of the passing the paper in feeder, it not always coincides. You it is necessary to apply to service service and do service. This not big worries. Good luck!
Sep 13, 2009 | Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL90 error after printing a couple jobs. I can restart and the error will clear but than comes back after a couple jobs. Is this a sensor or is it some other problem?
LL-90 and LL-91 refer to low toner and too much toner. If low, the cartridge is nearly empty, if too much, tape off half the holes on the cartridge.
Jun 15, 2009 | Xerox 8830 Copier
147 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
