Question about Xerox Phaser 8500/DN Printer
PCL5 Out of memory
Hi.
Word docs are fine, but if I want to print a glossy brochure off the internet the out of memory sign is printed instead. Can anyone help?
Thanks
Alex
Try setting the page scaling to "None". Worked for me.
Posted on Apr 07, 2011
    President:
  • 2,072 Answers
Is there a PS driver available for your machine? I would try downloading and installing that.
Posted on Jul 22, 2008
Need help to print brochures
You can take help from a brochure printing company that would provide you best attractive designed brochures for your business or service.
I can suggest you best template collection that you can use as a base template or for inspiration.
Brochure Templates PSD would provide you a wide range of templates which is designed carefully with best fonts, colors, and layouts.
Mar 12, 2012 | Office Equipment & Supplies
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
I have an error showing 49.4C02 on my laser printer 3700n What does this mean?
Press STOP to clear the print job from memory
Power cycle the printer
Try printing a job from a different application.
Try a different driver i.e. PCL5 instead of PCL6
If you have extra memory DIMMs installed, take them out and try printing.
Feb 08, 2010 | HP LaserJet 3700n Printer
PCL5 OUT OF MEMORY Phaser 8860
After reading some similar stories, I simply restarted the Xerox Phaser printer via the menu on the physical printer. I theorize perhaps the Phasers on board memory could have been bogged down from all the pictures involved in the problem documents and all the size problems associated with large files.
thorntravis
Oct 07, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
Blurry, Ink Smeared pages
If the media (glossy paper) is designed for an ink jet printer you should be fine.
Ink has to be able to be absorbed into the fibers of the page. If you are using paper for a laser color printer, that's your problem.
Don
Jun 19, 2009 | Ricoh Aficio CL7300 DT2 Laser Printer
HP Photosmart 7660 will not print Word doc.
Instead of clicking the printer icon, select File > Print and verify the correct printer is selected.
Feb 10, 2009 | HP PhotoSmart 7660 InkJet Printer
Imagerunner 1023if printing on glossy paper
Hello boriquajake,
We are looking at inherent limitations of the copier. The reason the paper appears "glossy" is that it is coated with a type of plastic that does not like going Thru whats called the fuser. This fuser does what its name implies as it "fuses" the toner to the paper by way of extreme heat and pressure. Thru decades of trial and error copier manufactures have found a way to make carbon black and plastique( like the EURO NAME?) along with other confidential compounds into a mixture (called toner) that can survive the extreme heat (370' F and above) and pressure (the sky is the limit here) bond to the paper and successfully exit. However, the nifty glossy paper was designed for an inkjet printer which uses sprayed ink and neither heat or pressure. My final most helpful statement would be that glossy paper was never designed for a copier. And I can promise you that at some point the glossy paper will cause a paper jam in the fusing area that will be very expensive . Since the "gloss " is merely a plastic shine that was never meant to be "re-melted" by the rubber coated rollers......... need I say more. One day you will have a paper jam from hell that will destroy the fuser. I wish I had better news but if you think about it I just saved you a service call, and a significant bill. You are are the working guys/ gals like me that I like to help before you get screwed. Take care.
Jul 19, 2008 | Canon imageRUNNER 1023iF Black and White...
Activity memory only has current day instead of
Open the speed dial cover,
press memory reference
press set.
this will print list of all docs in memory.
TO SELECT THE APPROPRIATE DOC.
Press memory reference
press the down or up to select print document
press set
press down or up to select transaction number
use the forward or back to select things like destination of doc
press set
press "star" to print 1st page or # to print all
Mar 05, 2008 | Canon FaxPhone L75 Plain Paper Laser
Printer issues
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :-
CTRL-P (to print with dialog box for changes)
Click on Properties
Select a Media type of glossy photo paper
Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
Oct 29, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Xerox Phaser  8500/DN Printer Logo
4,140 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
