Duct and suction fan
Duct = 76 cm diameter X 20 cm long
suction fun =81 cm diameter X 30 cm long
is this enough to heat my flatbed mechanical rice dryer
with a 21 sq. mtr floor area,
  • 97 Answers
Yes it is its plenty.
plz rate awnser. thanks.
Posted on Jul 22, 2008
Tradewinds VCH-6 and ventilator VR1000 on the roof, motor and fan blows but no suction
It's possible you have a motorized damper or fire damper in there. Likely at the ceiling. Or the duct has come loose. I would think if a damper was closed that fan wouldn't be blowing much air. Good Luck!!
May 02, 2017 | Heating & Cooling
WHAT IS THE AREA OF a circle with a diameter of 20 cm
Come on princess. Use the formula for the area of a circle: Area=PI*D*D/4
where PI can be entered using a key on the calculator, and D is the diameter.
Area =100*Pi cm^2 or about 314.159 cm^2
Feb 03, 2012 | Office Equipment & Supplies
A rectan Dear Madam Please look at the math questions below. Please help me solve the questions Question 1 : A rectangular tablecloth is 2.5 m long. Trim is to be sewn around the perimeter of the cloth...
1. Well this one is pretty simple. Since you are not supposed to trim the length trim the width instead.
to make the perimeter 0.4 m shorter cut the cloth by 0.2 m width the picture will make it clear.
2. let the length of rectangle be x cm
and breadth = 20 cm
now original perimeter = 2(x+20) cm
new length = x-30 cm
breadth remains same = 20 cm
new perimeter = 2(x-30+20) cm = 2(x-10) cm
According to question
new perimeter = old perimeter /2
2(x-10) = 2(x+20) /2
2x -20 = x + 20
x = 40 cm
hence length of longer side 40 cm.
If you want to directly comm ankitsharma.220@gmail.com
Feb 13, 2011 | Vivendi Excel@ Mathematics Study Skills...
Lost measuring cup
Here is a tip that I wrote that will help you with using your rice cooker to steam your veggies...
How to Steam Vegetables in your Rice Cooker
heatman101
Jan 05, 2011 | Zojirushi NHS-10 6-Cup Rice Cooker
High suction press (98psi), normal head press (140psi); full sight glass;low super heat (10 degrees);normal subcooling (13 degrees) new txv, new evaporator, new condensing unit 70 degree air from vents ...
lower fan speed.....and double check head pressure, sounds very low!!! should be around 250-275.....also make sure the return air grill is large enough.
Aug 09, 2010 | Goodman CLQ36AR49 Air Conditioner
2006 Nissan Sentra My problem started all of the sudden one day in the winter and now that its summer I cannot put it off. My heat, A/C, and defrost does not blow out of the vents. The fan works b/c I can...
it's not the duct work . there is a problem with your vaccum lines running to the motor. what's happing is the vaccum line is not getting enough suction to make the flap change that's why you hear it but don't feel it. check the vaccum lines for the a/c
Apr 06, 2010 | 2006 Nissan Sentra
A/c heating system has the fun blasting all the
the fan resistor is located in the duct work under the dash, usually near the blower on the passenger side, it is shorted out, you may have to remove glove box and some panesl to ger at it
Oct 26, 2009 | Hyundai Motor 2002 Sonata
Not enough return air to heating unit
Right now you are at bare minimun for what your unit requires. If you are not having any problems with the unit or have not had any I would not worry about it. You need to check and make sure that your duct size on the unit is not smaller than 14" in diameter. If it is 14" or bigger you are fine.
Dec 03, 2008 | Goodman CLJ30AR32 Air Conditioner
Goodman PCK-060-1C. suction 52, coil/filter/blower/restrictor/drier okay. Recovered the charge and recharged with factory specified amount. The return air 1800 cfm. Motor 3/4 hp. It seems to me the motor...
It seems to me that your suction should be @ 76 or so. 52 is low. the coil will ice up with any suction PSI below 58. Disconnect the unit from the duct work and make sure there is no restriction in the duct size. In other words. Does the unit work properly with out the duct? I find most mobil homes have a restriction in the amount of return. A 5 ton split needs a 20 inch round return. You never see this size return on a package unit. Does the return **** the filter in? I have had to add returns to large mobil homes because there just not designed right.
this is only a possibility. Is the temperature split on the equipment between 18 and 20 If it is then I don't thing you have an equipment problem. Also make sure there are no holes in the duct work.Last one I had unit was working fine but the duct work had a big hole in it from some animal under the trailer.
May 13, 2008 | Goodman PHKJ048-1 Air Conditioner
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
