Question about Harman Kardon AVR 500 Receiver
A/c Hum on r + l + c
Of late I have been getting an annoying hum on the RLC channels of AVR500. The SRSL channels seems to have no hum.
I have replaced the power strip with a high quality Belkin power strip
I have removed all the input sources and it still appears
When switching from source to source, the hum disappears briefly
I have uncoiled all the wires and laid it out straight
I have tried grounding the unit properly
I have tried grounding the Black terminal of the speaker
I am willing to open the Revceiver and replace any parts myself if I have enough info to try it out.
  • burgard2004 Nov 25, 2008
    My avr 500 makes a hum or buzz noize,more of a hum though.I've diconnected every thing from receiver,amps and all.Reconected it to other outlet with speaker and still get it.I,ve looked up a lot of information on buzzing/hum but it sounds like a ground loop problem.Is it an easy fix?Thanks steve
  • 2,335 Answers
The hum noise you are getting it could be producing due to a poor DC filtering due to leaky or dry capacitor(s) in the power supply section.
Pay attention to the biggest capacitors for bulging or leaky conditions.
Let me know if you need further assistance.
Posted on Jul 21, 2008
  • Jaime Hernandez Jul 21, 2008
    The capacitors could have a value of 10000uF/63v and you could also find 2200uF/35v but I would keep an eye on the bigger ones.
    Good Luck.
Whats wrong with my stereo
How old is your HK receiver? The power supply capacitors can get old and tired, and cause the hum and shutoff. Repair is an option.
May 03, 2015 | Harmon Kardon Harman Kardon AVR1600 50W/CH...
Hum on channel 2.
I assume that the hum exists without any cables plugged into the input. If that is not the case, then make sure all input cables and source are using BALANCED lines. If the hum is present with no input cables, since this is a tube type preamp, the input tube for the bad channel is first suspect. It is likely a 12AX7 or 12AT7 type tube. Since there are two channels, the first thing is to SWAP the two channels and see if the hum moves with the tube... if it does replace the tube. I have seen another problem with preamps in general where bypass capacitors from either side of the XLR connectors to ground get zapped with static and one side shorts. This reduces the gain by 6 DB and leads to hum.
Aug 30, 2011 | Behringer MIC2200 MIC.-PRE-AMPLIFIER
Nad c270 power amp transfomer hum
if the hum is in the sound output you have a blown power regulator
Mar 31, 2010 | NAD C270 2-Channel Amplifier
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Annoying hum from speakers w/system off
The big electrolytic capacitor(s) in the power supply. The filter out the 50/60HZ hum in the mains, so you could be hearing the mains hum!
Jan 02, 2010 | Memorex MX4100 CD Shelf System
Amplifiers has a hum
The hum therefore is a generated before it reaches the volume control. Check that all the connects are good, a bad earth will cause a hum. If the hum is in both channels it will be something that is common to both. Electrolytic Capacitors are there to take out hum, so suspect them first!
Jun 06, 2009 | JVC Audio Players & Recorders
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
I have a VSX-D901S Receiver which has been faithfully flawless for many years. Lately it developed a hum/buzz in the front amp when it is first turned on. If I leave it on for an hour or so the hum seems...
Yes it worth to repair it but you must bring into Pioneer factory or service center for Pioneer they are able to repair it
It require to replace a few electrolytics capacitors in power supply regulator if you are in AUSTRALIA it would cost between $150 to $250 to repair it
I hope that give you some idea
Cheers
Dec 03, 2008 | Audio Players & Recorders
Sunfire Mk II hum (different from greekboy post)
I had this issue a few years ago and the power cable from one of the inner terminals had come loose. It was still touching but whenever the sub would really pound it would jump off the connection and then reconnect causing it to hum. It was the most annoying thing ever so I finally pulled off the amp plate (super easy) and you could clearly see the loose wire. I had to use a good soldering iron to put it back on since it's a pretty fat wire. If you're not under warranty anymore then pop the back off and see if that's the issue.
-Dylan
Aug 17, 2008 | Sunfire True Sub MK II Subwoofer
My onkyo tx-sr705 produces a humming noise out off all the speakers when no audio is played
I found the source of my hum. I have Direct TV HD. I found that going into the menu settings (Direct tv HD Receiver) /Audio/Sound Effects and turning that option off, I was able to rid myself of the annoying hum. The option has something to do with keeping the audio settings from channel to channel, while it is changing you hear dead air except for the hum. Nice and quit now. Love this receiver!
Mar 06, 2008 | Onkyo Audio Players & Recorders
Harman Kardon AVR 500 Receiver Logo
206 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
