Question about Dometic Rooftop RV Air Conditioner
Air conditioner short cycling
I have a 59516.531 rooftop on my RV. I turn it on and on low speed fan t goes off really quick after a gurgling sound and then it pushes out hot air. If I have it on high speed it stays on for about 1 minute more and then does the same thing.
  • 1 more comment
  • hjdonnelly Sep 02, 2008
    Had a problem with rooftop A/C on 2000 Fleetwood Flair this weekend (first time out all season). Used generator (no electric available at campsite) and as soon as A/C was on for a few moments, it would sound like a 'load' being put on gen'y and A/C and gen'y would shut down...cleaned inside filter...went on roof, took cover off, cleaned what was visible to eye, but still would not work...it did blow very cold air before it shut off though...capacitor? relay switch? Don't know where to start? Refrigerant?
  • William Howe May 11, 2010
    I just now read your problem dated July 21st. Are you still having a problem? I have the same A/C unit and am having a similar but different problem. Let me know if you are still having a problem or have it resolved. At this moment mine is too much to write, but I will share my status. Thanks.
  • Mike Butler
    Mike Butler May 11, 2010
    When you say it goes off, are you referring to the compressor kicks out, then fan speeds up ? more details? First thing I'd check is if it's been cleaned good lately ? After you remove your filter inside, take a flashlight & look way up inside for cooling fins, (looks sort of like your car radiator, only smaller) that may be gummed up with dust & dirt. Needs to be cleaned if so. Then remove cover on roof, and inspect the back part that looks the same, clean if needed. Make sure you check both sides of it.See if that makes any difference in operation.
My Carrier package unit is goining off on short cycles. What should I trouble shoot first?
Posted on May 14, 2011
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Sounds like the thermostat probe is behind the filter,next to the coil,and not sensing good return air . just punch a hole through the filter so the bulb can sense return air! thank you-very-much!
Posted on Aug 28, 2008
My rooftop a/c unit makes a compressor noise as soon I as plug in my travel trailer. It's a 2009 Outback Sydney edition 310 bhs with a dometic a/c unit I believe. basically with the thermometer switch to...
The system blows cold air when turned to on position but also makes that sound between cycles
NOTE THE ON / AUTO SWITCH BETWEEN GREEN,FAN AND YELLOW ,COOL TERMINALS ON THE THERMOSTAT,
THE FAN SWITCH NORMALLY CLOSED GOES TO LOW, HEAT SPEED, WHILE THE NORMALLY OPEN GOES TO THE HIGH SPEED, COLING SPEED.
BY TURNING FAN ON NOTHING BUT FAN SHOULD RUN..
SWITCHING THE BREAKER TO OFF PRECLUDES THE UNIT FROM DOING ANYTHING !
WHAT CAN IT DO WITH NO POWER!
I switch the breaker to the off position when not using the a/c in order to keep this cycle from occurring. A
Sep 16, 2013 | Dometic Rooftop RV Air Conditioner
My ac turns on but just humms, no fan no cold air. a lil gurgling. it worked in my driveway,but when i arrived i can't get it to turn on.
your compressor is starting but the fan(s) are not running,leading to the shut-down of the unit, especially if the condenser fan doe's not operate for heat transfer off the condenser coil to remove the "latent" heat generated by the compressor so it is short cycling and will not keep running to cool this area
Jun 06, 2010 | Dometic Rooftop RV Air Conditioner
Our rooftop RV air conditioner will not cool on really hot days unless the fan is on all the time. Why won't it cool with the fan on auto?
You are asking a lot from a limited resource ... Let it run all day for best results. Make reasonable demands only ...
When you shave ... (you are a guy?) do you run your electric razor at 1/2 speed for best results?
When you curl your hair (you are a girl) do you run your hair dryer on low no heat?
May 31, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
A/c won't shut off have to use breaker
sounds like your run capacitor has failed you can find it if you remove the top cover there is a side acess were there is a lot of wires coming out remove that acess there should be 3 capacitors 1 fan 1 start 1 run make sure to turn the braker off before checking the capicitors remove the run capicitor & check for shorts
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,739 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
