Question about Sony Handycam DCR-SR200 Camcorder
Sony DCR-SR200 screen slowly "scrolls" vertically like the V-Hold on an old television
I purchased a Sony DCR-SR200 camcorder less than one year ago from a Best Buy. Just the other day, I turned it on and the LCD screen started "scrolling" vertically. The entire screen scrolls continuously, including the menu. Have you seen that problem before
  • 6 more comments
  • tschlueter Aug 06, 2008
    This model does not have a viewfinder, only the LCD screen
  • Anonymous Aug 10, 2008
    I have the same problem with my DCR-SR200, I took it apart and concluded there is a thin cable that has a broken wire segement, if I press just right on the cable, the screen is fine. Now, where to find a replacement cable?
  • prorpy Aug 11, 2008
    Since a few days I have the same problem with my dcr-sr35. Has any of you found a solution for this?
  • Anonymous Sep 01, 2008
    If I gently twist the viewfinder back to the "close" position, the scrolling stops.
    I thought it might be a loose cable, so I took the camera nearly completely apart and reseated all viewfinder cables. There are two - one that has the video signal, and one that detectes when the viewfinder is flipped 180 degrees to the front.
    Didn't old TVs do this when they lost vertical sync? Could this be a bad diode or some other failed electronic component in the viewfinder?
  • rjc62 Sep 01, 2008
    My SR200 just started doign this today. I thought it was a loose cable, but I took the camera (completely) apart and reseated them - it fixed it at first, but after a few power ons, the problem returned.
    Didn't old TVs have a scrolling problem like this when they lost vertical sync? This seems like it would be localized on the controller board behind the viewfinder, like a bad diode or something.
  • scottm2705 Sep 06, 2008
    I have same problem. The video screen rolls. Sometimes the background is also dark. I've taken it apart and reassembled five times. It seems like a switch is not engaging/dis-engaging properly. There are two micro-switches, one turns the screen on when the door is opened, the other flips the display when twisted to the front position. I even disassembled the switch that turns the screen on and no change. (I don't recommend this; it requires a magnifying glass and tremendous patience - plus, it didn't help). I'm thinking it may be a loose solder connection, possibly on a small capacitor mounted on the touch-screen circuit board. Very frustrating.
  • agot356 Mar 21, 2009
  • ashu30 May 11, 2010
    can anyone give me instrcutions on how to open the silver panel to view the ribbon, i took all screws off and the black hard disk panel comes off...cant get the silver one to open, do i need to open screws 3 on LCD panel
After researching various flexible cable numbers from different posts, I found that the SR-200 uses a unique cable, FP-610, part number 187145711. This has been discontinued and replace with part number 187145721 (same cable also used in DCR-SR300).
If you are in doubt with your camera, just take it apart up to the point of seeing the ribbon cable. The part number is printed on the side.
I found two sources for this so far, www.nexttronics.com and https://servicesplus.us.sony.biz/sony-parts.aspx. Price ranged from $30 to $40 plus shipping.
Posted on Sep 14, 2008
  • 752 Answers
Does it do it on both the LCD and the viewfinder?
Posted on Aug 05, 2008
  • Mitch
    Mitch Aug 07, 2008
    Do a quick experiment... While the screen is rolling, gently give the camera a few raps on either side of the hinge area. Also, gently twist the screen along various axis.
    While performing these actions, does the roll change or stop?
My Sony Handycam DCR-SR200 Camcorder has no display
The flexy cable between lcd and main pcb is faulty replace it
Aug 08, 2011 | Sony Handycam DCR-SR200 Camcorder
We are experiencing some problems with our sony handycam dcr-sr200. The screen is scrolling upwards. It just started and we don't know how to fix it? Can you help?
Hi!
It's most likely a broken LCD flex cable which goes through the hinge. It's a common problem with these cameras. I repair them every day as I work in a Sony service center. If you're out of warranty, talk to Sony, maybe they are ready to pay half of the repair or something like that as I believe it's a factory fault.
Hope this helps!
Tom
Oct 09, 2009 | Sony Handycam DCR-SR200 Camcorder
Scrolling screen and dark LCD screen
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
Jul 12, 2009 | Sony Handycam DCR-SR200 Camcorder
Sony sr200 scroll issue
Hi, I just fixed mine. I have the sr200 and my screen would flicker and shut off unless I held it in a certain position. Ordered the the 2 flat cables and after i installed them I got a rolling screen.Upon further inspection I found that the wider of the 2 flat cables wasn't inserted all the way. That fixed my problem.BTW the 2 flat cables cost me $53 with shipping verus $170 that some company wanted to charge for the fix.Hope this helps.
Jan 03, 2009 | Sony Handycam DCR-SR200 Camcorder
SONY DCR-SR200
DCR-SR200 is complicated camera and pls contact nearest Sony service shop for proper repair.
Jul 15, 2008 | Sony Handycam DCR-SR200 Camcorder
Sony Handycam  DCR-SR200 Camcorder Logo
2,286 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
