Question about Dell Dimension 3000 PC Desktop
Memory upgrade in Dell Dimention 3000
Removed old 256 sticks (2) and replaced with 2 1gig sticks all specs match. Now computer will not power on ( no green light except on drives)
What happened? Put old memory back in and now same thing
  • naves71 Jul 30, 2008
    I to have the same problem patr6770 has. I upgraded from (2) 256 memory sticks to (2) 1GB. The Dimension 3000 is capable of handling 2GB of memory. I have tried placing just one stick at a time and making sure i hear a click when doing so...still no luck.I have checked all cables making sure that nothing was loose. The bad part of this is that when i reverse the process and put my old memory sticks back in...still just get a black screen. pls help
    Problem Solver:
  • 7 Answers
Hi there......ok here is a mayb e dumb question but I see people do this so.... you did not attempt to remove or install the memory while it was on did you? If so, the motherboard is most likley now toast..... IF NOT, I see Dells do this once in a while as well. You will need to flash the bios by moving the BIOS jumper to it;s other position and power up the PC..... it may or may not power up. Then replace and try to power up again. IF NO LUCK.... contact me and we can go over some other options! FUN =)
Posted on Jul 30, 2008
    Genius:
  • 1,011 Answers
Dear,
remove 1 memory stick b'coz its possible ur pc couldnt support 2gb of memory. try 1 first. if ok then try 2nd only. if both works then its mean ur system doesnt support it. also reconfirm the bus speed of both rams. should be matched.
regards,
salman
Posted on Jul 21, 2008
    Problem Solver:
  • 8 Answers
Please take one of the memory cards and try and try the same card in all the slots also try the second memory card. Also check if your getting the memory beep at the start up and dell diagnostic lights all the lights should be green
Hello, I was looking to upgrade the ram in my old dell 5150. The specs say you can use a Max of 4 1 gig sticks yet these specs where released prior to windows 7 ultimate which uses far more ram. What are...
Check www.crucial.com. Use the downloadable program to analyze your system or use the interactive menu system to explore your options.
Check online forums using google searches for terms like 'dell 5150 memory upgrade'. Sometimes, the maximum in the manual is not the real maximum. My Dimension 1000 laptop accepted a certain 1 GB card when the manual said the max was 256MB. Still running it after nearly ten years. The laptop was **** with 512MB (256 built-in and 256 add-on card) but the gf uses it every day.
Sep 13, 2012 | Computers & Internet
Need to find the right memory ram to upgrade to 1gig as i only have 256 stick in it.i need to know the right specs and module number
Since you're planning to upgrade the RAM of your computer here are the 3 different type of RAM that you can use for this motherboard.
400MHz(PC2-3200)
533MHz(PC2-4200)
667MHz(PC2-5300)
Sep 30, 2010 | Foxconn 6627MA-RS2H Motherboard
Can I install one (1-gig) memory stick instead of 2 match pairs (only have one) this is to replace two 256 sticks?will it preform at 1 - gig memory
Yes.
The Maximum Total Amount of Ram Memory is 2GB.
(2048MB)
The Maximum Amount for EACH ram slot is 1GB.
(1024MB)
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Note*
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
May 21, 2010 | Dell Dimension 3000 PC Desktop
I want to upgrade my RAM on my eMachine t3504. I currently have 256 in each of my 2 slots. Can I upgrade one of the slots to 1 GB and leave the 2nd at 256 or do I have to upgrade both slots?
Yes you can upgrade 1 of the slots to 1GB, as long as 1GB stick of memory is the 256MB stick then you can have both, to check the memory you will have pull them out of the slots and have a look on a little sticker on one side of them. You are looking for i.e DDR400/333/266 if the 1GIG memory matches one of the values mentioned above, say it is a DDR400 and the 256 is a DDR400 then they are compatable if not you will have to just leave the 1GIG stick in by it self in DIMM socket 1.
Apr 03, 2010 | E-Machines T3504 PC Desktop
Dell dimension 3000 with winxp os.Want to upgrade my ram from the 1 256mb/400mhz to 2 1gb sticks ,dell site says i can use up to 2 gb.So i power down and intall the 2 ddr2700/333 sticks that are required...
Your memory modules may be ECC or Registered (which are mainly used for Servers). They will fit in the slots, but your System will not post with them. I would suggest returning the RAM you purchased, and replace with 2 x 1GB DDR PC3200 400MHz non-ECC Unregistered Memory Modules. A matching pair is preferred.
If you receive a "Memory available limited to 256MB!" message after installing more than 256MB, enter BIOS (F2) and turn OS Install to OFF. Exit saving changes.Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
You may also wish to update to the latest BIOS for this model from the Dell Support Site: http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=DIM_CEL_3000&os=WW1&osl=en&catid=&impid=
Jan 12, 2010 | Dell Dimension 3000 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Computer will not work with extra 1gb ram
It sound like you have incompatible memory. Try taking out the original 256 and test with the 1 gig. Keep in mind some PC requires memory to be paired. If you only have one, 1gig memory chip you might need to get another. I would try removing the 256 first. The specification of the motherboard would also tell you the memory usage.
Let me know if this helps!!
Joe
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
Dell dimension 4550
Dell has a habit of using proprietary memory in their machines, if it isn't proprietary you can near guarantee that cheaper memory sticks will not be recognised.
Play safe and use the memory configurators at crucial.com and newegg.com
I bought two DDR2 1gig sticks at crucial yesterday for $50.00 for both with free shipping.
Jul 24, 2008 | Kingston 1GB PC2700 DDR DIMM Memory
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
252 people viewed this question
Alun Cox
