Question about HP DesignJet 1050c plus InkJet Printer
Print head path
We are trying to plot and get a message to turn power off and check print head path(2)
  • 1 more comment
  • whirsch Jul 21, 2008
    hope to get help from you guys
  • kevinrs Sep 18, 2008
    We have the same error message, cleaned belt and rods last year. Recent service call inidcated a carriage motor, sensor in carriage, or sensor in service station, all with increasing costs...Not really confident in diagnosis, as technician suggests all out replacement...any input is helpful.
  • KIERAN2006CF Nov 11, 2008
    WHEN TRYING TO LOAD PAPER THE PLOTTER COMES UP SAYING SWITCH POWER OFF PRINTER HEAD TYPE 2 HELP NEEDED ANY IDES ON HOW TOP FIX
  • 71 Answers
Did You Try cleaning the Encoder. If so could be a bad belt , Pully, Or service station.
Posted on Jan 15, 2009
  • HP Expert
  • 141 Answers
This is 90% of the time a worn belt caused by lack of oil on the slider rods.
Posted on Sep 03, 2008
  • 138 Answers
Sounds like a belt tensioner bearing going bad. That is if you haven't found any paper lodged in the way, the carriage bar is lubricated well and the belt is in decent shape. The belt tensioner is at the left end where the belt turn around. inside the wheel at the end is a bearing the starts to seize as it gets old and causes the error. You'll probably have to order a tensioner assembly. The part can be found on http://partsurfer.hp.com.
Here's a link to the complete service manual for the plotter.
http://www.feedroller.com/Store/Service%20Manual/DESIGNJET%201050C,%201055CM%20Large%20Format%20Service%20Manual.pdf
Hope that helps you.
Posted on Aug 03, 2008
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
Error-check printhead path 2
After plot one ploter going to print head check mode on dsj 1050.
May 17, 2010 | HP DesignJet 1050c plus InkJet Printer
Carriage Jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 08, 2010 | HP Officejet Pro 850 InkJet Printer
We are receiving the error message Check Print Head Path Type 2 when trying to plot to our designjet 1050C. The carriage makes a slight clicking noise on the left side of the rod. Does anyone have a fix...
Upon power up, does the machine move the carriage assembly from one side to the other?
Generally, any message like that means the belt has a few teeth missing or is worn. The belt drives the carriage assembly to and fro. If the machine detects a slow down or stop, it will have you check the printhead path for obstructions. If there aren't any, then 9 times out of 10 it is a worn belt. Check for little pieces of black rubber under the belt and encoder strip.
I have also seen 2 other fixes: a dirty encoder strip (the plastic strip with little hash marks on it) and a faulty cutter. But most of the time it is the belt.
Apr 22, 2010 | HP DesignJet 1050c InkJet Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
HP Designjet 1050c begins to plot, then stops plotting with the error message "Turn of printer, check printhead path". What is the problem?
you need to lubricate the slide bar with some thin oil ( sewing machine oil).put the oil on your finger and then touch the bar this way you wont spil oil into the printer
Nov 03, 2009 | HP DesignJet 1050c InkJet Printer
ON MY HP750C EVERY PLOT WANTS TO SERVICE THE CARTRIDGE RATHER THAN PLOTTING CONTINUOUSLY so i have to sit by the plotter rather than plotting a batch.
disable pen check option thru Front Panel Menu Button
it will not check the cartridges & not service the cartridge
Jul 02, 2009 | HP DesignJet 750c InkJet Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
367 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
