NetGear MBR624GU Wireless Router Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I use a vodafone wireless dsl router with vodafone as my ISP with a 40 (or 80, i forgot)GB download allowance package per month.my problem is , that whenever my family or i use the internet for a while , the internet cuts off and i have to wait for an hour or so to be able to go on again, whats going on ?
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Feb 04, 2011
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
524258
Points
8345
You need to raise a case with the support section of your ISP, also make sure none of your neighbours are using your internet by password protecting the router login and using the built in WPA encryption.
I hope you found my reply helpful please ask if there is anything else.
regards
Hi I would like o hook up a netgear prosafe 8port gigabit switch to my pc and run an ethernet cable which is allready hardwired to my sony bluray player so I can enjoy netflix
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
2answers
We have four computers with a Belkin 54g wireless router. One computer is connected to our dsl bya cable. The other 3 are using wireless. Whenever one of the computers gets on the network, neither of...
You need to attach the Belkin 54g wireless router to the DSL/cable modem. Then have all the computers connect wirelessly to the belkin. They should then be able to get out.
3helpful
2answers
I have been offered a Netgear N150 DGN1000 Wireless ADSL modem Router new for only £25.00 from a friend, however it has a sticker on the box that says ''For BT Connections''. I wanted to know if this...
Well this product DGN1000 is a generic router supplied by Netgear and can be used with any ADSL/DSL ISP. Please ensure that you upload the latest firmware for this router from the netgear support site and then you can use it with other ADSL/DSL ISP.
Hope this allows you to resolve the issue. If you need further assistance then let me know.
Regards
Anand
2answers
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Very low signal
Given that you have a '802.11B' device, the maximum speed will be 11 Mbps.
While your wireless router is communicating at that speed to your computer, the router is communicating with your ISP at a much-lower speed, depending on how much you pay per month to your ISP for the agreed-upon level of service, e.g., "ADSL-lite" or "High-Speed".
So, unless you pay more per month to your ISP, the "bottleneck" will be between your ISP and your router, *NOT* between your router and your wireless adapter.
Now, as to the "low signal strength", that's a matter of the distance between the router and your computer, and the number and composition of the walls and ceilings in the middle.
If you move your computer closer to the router, the signal-strength should become "good" or "excellent".
A friend gave me old 2Wire 1701HG wireless modem/router. It didn't come with power cord, cables etc. I found a 4.5V cord from old walkman that worked. Anyway, have ATT DSL service with speedstream 4100...
That would seem to be AT&T's favorite house brand...
Me thinks the SpeedStream was their SLOWEST
"DSL"
"2wire" was their next iteration of SLOW "DSL"
Yes... You will need to contact THEM ... or whom-so-ever is your INTERNET SERVICE PROVIDER (ISP)...
As I recall... the PRICE DIFFERENCE from one
service to the other was about $10 per month.
Give them your pirated modem number and they
will need to register it as a digital subscriber
in order for you to gain internet access.
Carnac the Magnificent
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
Cd rom download
the links below will show you how to manually install the device on your network
Setting up your Linksys router for Cable ISP
Setting up your Linksys router for DSL ISP
Setting up your Linksys router to have wireless security.
if you have other questions just let me know.
T! lines
A T1 line is a dedicated connection to an Internet backbone router. Typically a T1 line is for major businesses and school campuses. A T1 line is capable of handling 637 simultaneous VOIP connections with full-duplex connection.
How many computers do you intend to have connected to this network? Even a fractal T1 is very expensive. A full T1 connection can cost nearly 25K per month usage. A T1 line will need to be installed by your ISP provider and this too will cost a significant amount of money and it depends on how close your network connection will be in relation to the main network trunk-line.
If you trying to connect a T1 line to a Belkin 54g wireless router, you are way out of your league. I have worked for several networking firms in the Atlanta, GA area and we never had more than a fractal T1. Most small to midsized networks (up to 100) users can be accommodated with using a DSL or Cable Internet connection with a dedicated firewall and router/switch to handle the network traffic. Unless you are willing to pay for a T1 fiber optic line to be run from the main trunk line to your place of business or home, you will be fine with a high speed cable internet connection from an ISP provider like Comcast of Qwest here in the US. Fiber still has an installation cost of about $10,000USD per 1000 feet.
Hope this helps to clarify your problem.
Cheers,
Keith
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
