Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite The pump to drain the dishwasher won't shut off.  I think the timer motor is the cause...any suggestions?
The time is flashing 42 on my kenmore elite front loader but when u presss the buttons noting happens
Posted on Aug 03, 2008
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
http://www.youtube.com/watch?v=vNQvDqzMZV4
May 27, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher will not drain water
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Jan 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Water does not completely drain on Kenmore Elite.
Hi..
If your machine does not drain you need to check this
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Before testing the lid switch, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
Regards
PCmania
Aug 19, 2009 | Siemens 24 in. SE64A630GB Built-In...
Our kenmore washer wont drain
Try these
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
pls rate my suggestion.......
Jul 22, 2009 | Kenmore Elite 45986 Front Load Washer
Motor not working
Your motor is attached to the pump,your pump seal is locked up needs replacing or purchase a new pump.Because it is a job replacing seal,if your a first timer.
Apr 10, 2009 | Kenmore Elite 20972
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Sep 21, 2008 | Kenmore 24 in. 17594 Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
